Tass
Re: Arch Linux Enable SSH
Wed May 02, 2012 11:28 am
benzeman said:
Is there a way to check the IP arch has within arch? I used the bt home hub (v2.0a if it helps), and it reported the IP stayed the same.
I use ifconfig on debian - not sure if it's the same for Arch?
RationalLime
Wed May 02, 2012 12:06 pm
It would probably be easiest to set a static IP just to make sure it doesn't change.
Also:
- Correct IP?
- Correct port?
- Correct protocol? (relevant for non-terminal access)
pepedog
Wed May 02, 2012 12:10 pm
ifconfig
To make static, edit /etc/rc.conf example there, and comment out dynamic entry
benzeman
Wed May 02, 2012 5:39 pm
Solved - using debian instead (seems more appropriate for a web server...)
pepedog
Wed May 02, 2012 7:14 pm
I disagree. I got 2 arch arm doing this, and much more.
