melvin0918
How can i stop this?
Fri Aug 23, 2013 12:53 pm
I got a bit of a problem...
When i'm connecting to my openvpn over wifi, the wifi disconnects :x
So i no longer can connect to my openvpn access server. :S
This also happen when i plug in a ethernet cable.
Please, can anyone help me.
mrpi64
Re: How can i stop this?
Fri Aug 23, 2013 4:13 pm
Sometimes, when you log into gmail on netsurf, google thinks that you are a hacker, so that you can't access gmail. Maybe something is not designed for the Pi?
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
melvin0918
Fri Aug 23, 2013 5:44 pm
mrpi64 wrote:Sometimes, when you log into gmail on netsurf, google thinks that you are a hacker, so that you can't access gmail. Maybe something is not designed for the Pi?
Thats not what i ment, i ment the 'ifplugd' disconnects wifi when i plugin a network cable. OpenVPN uses a virtual network 'tun0'.
If i connect it virtual puts in a network cable. I don't want to turn it off!
Hove
Sat Aug 24, 2013 6:33 am
Have a look in /etc/default/ifplugd (it's just a text file). If HOTPLUG_INTERFACES is set to all, try replacing "all" with just "eth0".
That should (although I've not tested it) stop ifplugd meddling with your WiFi - of course it also stops the WiFi hotplug function, so don't unplug it!
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
