Thanks!~
New USB device found, idVendor=1bc7, idProduct=1010
Aug 22 21:17:15 raspberrypi kernel: [ 3.329686] usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Aug 22 21:17:15 raspberrypi kernel: [ 3.349493] usb 1-1.2: Product: Telit HS-USB Modem
Aug 22 21:17:15 raspberrypi kernel: [ 3.359431] usb 1-1.2: Manufacturer: Telit Wireless Solutions
Aug 22 21:17:15 raspberrypi kernel: [ 5.292313] usbcore: registered new interface driver usbserial
Aug 22 21:17:15 raspberrypi kernel: [ 5.449401] USB Serial support registered for generic
Aug 22 21:17:15 raspberrypi kernel: [ 5.613703] usbcore: registered new interface driver usbserial_generic
Aug 22 21:17:15 raspberrypi kernel: [ 5.622879] usbserial: USB Serial Driver core
Aug 22 21:17:15 raspberrypi kernel: [ 6.006823] USB Serial support registered for GSM modem (1-port)
Aug 22 21:17:15 raspberrypi kernel: [ 6.273445] option 1-1.2:1.0: GSM modem (1-port) converter detected
Aug 22 21:17:15 raspberrypi kernel: [ 6.368354] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Aug 22 21:17:15 raspberrypi kernel: [ 6.478130] option 1-1.2:1.1: GSM modem (1-port) converter detected
Aug 22 21:17:15 raspberrypi kernel: [ 6.590132] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Aug 22 21:17:15 raspberrypi kernel: [ 6.674188] option 1-1.2:1.2: GSM modem (1-port) converter detected
Aug 22 21:17:15 raspberrypi kernel: [ 6.753212] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Aug 22 21:17:15 raspberrypi kernel: [ 6.790354] option 1-1.2:1.3: GSM modem (1-port) converter detected
Aug 22 21:17:15 raspberrypi kernel: [ 6.848219] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Aug 22 21:17:15 raspberrypi kernel: [ 6.898923] usbcore: registered new interface driver option
Aug 22 21:17:15 raspberrypi kernel: [ 6.932643] option: v0.7.2:USB Driver for GSM modems
Aug 22 21:17:15 raspberrypi kernel: [ 9.663099] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Aug 22 21:17:15 raspberrypi kernel: [ 10.134648] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Aug 22 21:17:15 raspberrypi kernel: [ 10.866015] bcm2835 ALSA card created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.872433] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.892218] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.903852] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.909985] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.926042] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.934181] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 10.942148] bcm2835 ALSA chip created!
Aug 22 21:17:15 raspberrypi kernel: [ 20.546954] bcm2835-cpufreq: switching to governor ondemand
Aug 22 21:17:15 raspberrypi kernel: [ 20.546982] bcm2835-cpufreq: switching to governor ondemand
Aug 22 21:17:15 raspberrypi kernel: [ 20.648681] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Aug 22 21:17:16 raspberrypi kernel: [ 23.333177] Adding 102396k swap on /var/swap. Priority:-1 extents:129 across:1754856k SS
Aug 22 22:25:05 raspberrypi kernel: [ 337.683036] usb 1-1.2: USB disconnect, device number 4
Aug 22 22:25:05 raspberrypi kernel: [ 337.683570] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Aug 22 22:25:05 raspberrypi kernel: [ 337.683671] option 1-1.2:1.0: device disconnected
Aug 22 22:25:05 raspberrypi kernel: [ 337.687353] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Aug 22 22:25:05 raspberrypi kernel: [ 337.687456] option 1-1.2:1.1: device disconnected
Aug 22 22:25:05 raspberrypi kernel: [ 337.688005] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Aug 22 22:25:05 raspberrypi kernel: [ 337.688090] option 1-1.2:1.2: device disconnected
Aug 22 22:25:05 raspberrypi kernel: [ 337.688601] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Aug 22 22:25:05 raspberrypi kernel: [ 337.688688] option 1-1.2:1.3: device disconnected
Aug 22 22:25:12 raspberrypi kernel: [ 345.084985] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
Aug 22 22:25:12 raspberrypi kernel: [ 345.187525] usb 1-1.2: New USB device found, idVendor=1bc7, idProduct=1010
Aug 22 22:25:12 raspberrypi kernel: [ 345.187554] usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Aug 22 22:25:12 raspberrypi kernel: [ 345.187571] usb 1-1.2: Product: Telit HS-USB Modem
Aug 22 22:25:12 raspberrypi kernel: [ 345.187583] usb 1-1.2: Manufacturer: Telit Wireless Solutions
Aug 22 22:25:12 raspberrypi kernel: [ 345.197847] option 1-1.2:1.0: GSM modem (1-port) converter detected
Aug 22 22:25:12 raspberrypi kernel: [ 345.198306] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Aug 22 22:25:12 raspberrypi kernel: [ 345.198852] option 1-1.2:1.1: GSM modem (1-port) converter detected
Aug 22 22:25:12 raspberrypi kernel: [ 345.199288] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Aug 22 22:25:12 raspberrypi kernel: [ 345.199838] option 1-1.2:1.2: GSM modem (1-port) converter detected
Aug 22 22:25:12 raspberrypi kernel: [ 345.200414] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Aug 22 22:25:12 raspberrypi kernel: [ 345.201059] option 1-1.2:1.3: GSM modem (1-port) converter detected
Aug 22 22:25:12 raspberrypi kernel: [ 345.204064] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Aug 22 23:07:34 raspberrypi kernel: [ 2887.184201] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
Aug 22 23:07:34 raspberrypi kernel: [ 2887.184249] mmc0: DMA IRQ 6 ignored - results were reset
Aug 22 23:07:34 raspberrypi kernel: [ 2887.185164] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
Aug 22 23:07:34 raspberrypi kernel: [ 2887.185205] mmc0: DMA IRQ 6 ignored - results were reset
Aug 22 23:09:36 raspberrypi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Aug 22 23:09:36 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="11203" x-info="http://www.rsyslog.com"] start
Aug 22 23:15:59 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="11203" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Aug 22 23:31:49 raspberrypi kernel: [ 4342.016144] usb 1-1.2: USB disconnect, device number 5
Aug 22 23:31:49 raspberrypi kernel: [ 4342.016740] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Aug 22 23:31:49 raspberrypi kernel: [ 4342.016852] option 1-1.2:1.0: device disconnected
Aug 22 23:31:49 raspberrypi kernel: [ 4342.020367] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Aug 22 23:31:49 raspberrypi kernel: [ 4342.020487] option 1-1.2:1.1: device disconnected
Aug 22 23:31:49 raspberrypi kernel: [ 4342.021204] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Aug 22 23:31:49 raspberrypi kernel: [ 4342.021295] option 1-1.2:1.2: device disconnected
Aug 22 23:31:49 raspberrypi kernel: [ 4342.021965] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Aug 22 23:31:49 raspberrypi kernel: [ 4342.022070] option 1-1.2:1.3: device disconnected
Aug 22 23:32:18 raspberrypi kernel: [ 4370.669084] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Aug 22 23:32:18 raspberrypi kernel: [ 4370.771247] usb 1-1.2: New USB device found, idVendor=1bc7, idProduct=1010
Aug 22 23:32:18 raspberrypi kernel: [ 4370.771278] usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Aug 22 23:32:18 raspberrypi kernel: [ 4370.771295] usb 1-1.2: Product: Telit HS-USB Modem
Aug 22 23:32:18 raspberrypi kernel: [ 4370.771308] usb 1-1.2: Manufacturer: Telit Wireless Solutions
Aug 22 23:32:18 raspberrypi kernel: [ 4370.778827] option 1-1.2:1.0: GSM modem (1-port) converter detected
Aug 22 23:32:18 raspberrypi kernel: [ 4370.780804] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Aug 22 23:32:18 raspberrypi kernel: [ 4370.781482] option 1-1.2:1.1: GSM modem (1-port) converter detected
Aug 22 23:32:18 raspberrypi kernel: [ 4370.782022] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Aug 22 23:32:18 raspberrypi kernel: [ 4370.782664] option 1-1.2:1.2: GSM modem (1-port) converter detected
Aug 22 23:32:18 raspberrypi kernel: [ 4370.785390] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Aug 22 23:32:18 raspberrypi kernel: [ 4370.786169] option 1-1.2:1.3: GSM modem (1-port) converter detected
Aug 22 23:32:18 raspberrypi kernel: [ 4370.786770] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Aug 22 23:49:05 raspberrypi kernel: [ 5377.833600] cdc_acm: disagrees about version of symbol module_layout
