clarkpadgett
FTP kernel.img to your SD card.
Tue Aug 20, 2013 1:22 pm
After reading a blog where a guy had hacked a Transcend Wi-Fi SD card (http://haxit.blogspot.ch/2013/08/hackin ... cards.html), I ordered one to see what I could do with it. It turns out I can start an FTP server and transfer my kernel.img directly to the SD card. First, I downloaded the latest version of busybox for the processer in the card from http://busybox.net/downloads/binaries/l ... box-armv5l and stored that in the root of the card. Then, I created a script named autorun.sh (also stored in the root) that contained:
#!/bin/sh
cp /www/sd/busybox-armv5l /sbin/busybox
chmod a+x /sbin/busybox
/sbin/busybox telnetd -l /bin/bash &
/sbin/busybox tcpsvd -vE 0.0.0.0 21 ftpd -w /www/sd &
This starts the FTP server and also a telnet server that I use to explore the Linux system running the Wi-Fi. Just FTP kernel.img to the Wi-Fi address, cycle the power on the Pi, and your new kernel is running. One thing that is not so great is that the Wi-Fi takes around 50 seconds after power up to become available. My plan is to rig up a reset button connected to P6 on the Pi so that the power does not have to be cycled to run the new kernel.
JazzD
Re: FTP kernel.img to your SD card.
Wed Aug 21, 2013 6:41 pm
wow that is awesome, just what i need.
dhavalx
Fri Jan 03, 2014 10:07 am
It would help me for my product...Thanks..By xtintt.com :idea: http://www.raspberrypi.org/phpBB3/posti ... 340d1a4eb9#
pointfree
Sat Jan 04, 2014 7:21 pm
I have been doing something similar with raspbootin and a reset button on a breadboard. All I have to do is "make" and then press the button to boot up the new kernel over serial. Raspbootin has saved me much time.
mram
Mon Jan 13, 2014 12:31 am
I would like to buy for my sony nex5, it could be nice to use with my Amiga RPI Drive, customizing web server with some useful script... :D :D
sk83
Mon Jan 13, 2014 5:38 pm
I've set up mine with u-boot and tftp. Every time the rpi boots, it loads kernel.img over ethernet. My makefile copies kernel.img to the tftp root directory(my mac acts as the tftp server). Then I just push the reset button connected to P6 to reboot and reload kernel.img. Works like a charm.
Return to “Bare metal, Assembly language”
