kingoslo
How to automatically exec startup command after OS boot?
Sun Aug 18, 2013 3:38 pm
Hello there,
I would like to:
$ okular /path/to/file.pdf --presentation
This line launches the app named okular in presentation mode (typical slideshow format). I want this to happen automatically every time OS boots.
Somebody suggested I make a sh-script with this exact line of code in it, and add "/path/to/script.sh" into /etc/rc.local. I did this, but the app does not launch after startup at all.
How should I proceed?
Thank you for your time.
Kind regards,
Marius
joan
Re: How to automatically exec startup command after OS boot?
Sun Aug 18, 2013 3:49 pm
You might need to have the full path to okular in /etc/rc.local, i.e.
/usr/bin/okular /path/to/file.pdf --presentation &
kingoslo
Sun Aug 18, 2013 4:08 pm
Ok, so this is what I did.
I made one file /home/pi/present.sh. All it contains is:
#! /bin/bash
/usr/bin/okular beamer.pdf --presentation &
This is the entire contents of rc.local:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
/home/pi/present.sh
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
exit 0
It does still not launch okular after startup.
Kind regards,
Marius
joan
Sun Aug 18, 2013 4:18 pm
Have you made the script executable?
chmod +x /home/pi/present.sh
kingoslo
Sun Aug 18, 2013 4:24 pm
joan wrote:Have you made the script executable?
Yes I did.
What do you think?
Thanks.M
joan
Sun Aug 18, 2013 4:27 pm
I've no idea. What you have done should work.
What happens if you type
/home/pi/present.sh
kingoslo
Sun Aug 18, 2013 4:34 pm
joan wrote:I've no idea. What you have done should work.
/home/pi/present.sh
Typing this into the terminal launches okular.
joan
Sun Aug 18, 2013 4:38 pm
Perhaps your variant of Linux doesn't use /etc/rc.local. I'm fairly sure the Debian based distributions do use /etc/rc.local. Which distribution are you using?
topguy
Okular is a X-windows application right ?
rc.local is probably run before x-windows starts. You'll have to wait until both X and your window-manager is started to start Okular.
I assume that you have enabled the x-windows desktop and made so the user "pi" is automatically logged in.
Read this for tips on having LXDE start your application. (the wiki is for Archlinux but I assume LXDE behaves similar on debian/raspbian)
https://wiki.archlinux.org/index.php/LX ... t_programs
kingoslo
Sun Aug 18, 2013 5:06 pm
Not sure what x-windows app is, but perhaps this answers the question: okular is an app with a GUI, just like Midori. Yes I believe this is the reason it isn't working.
I read the document which you recommended. Under the sub-heading autostart file, the author refers to "~/.config/lxsession/LXDE/autostart". -- The first problem is that I am unable to find the directory lxsession.
Second, I do not understand any of what is written under the sub-heading .desktop files. Never heard of any of that, so unfortunately it makes no sense to me :cry:
This is what I am keen to do: I think it could be best to find a way to launch a script after all of the required stuff has been started, that way I could not only start okular, but start okular in display mode using this line:
How can I do that?
Kind regards,
Marius
topguy
Sun Aug 18, 2013 5:34 pm
If you type "autostart" in the search box in the top right corner you will find other threads on this subject.
This is one:
http://www.raspberrypi.org/phpBB3/viewt ... rt#p395147
kingoslo
Sun Aug 18, 2013 7:21 pm
topguy wrote:If you type "autostart" in the search box in the top right corner you will find other threads on this subject.
This is one:
That worked!
Takk kompis.M
Return to “Beginners”
