(Positive and negative end are marked on the speaker)
Thanks, I want to cut the wire of the audio jack open and see what's inside. There probably are 3 wires inside: ground, one for the left earbud and one for the right. But I have one speaker, isn't it going to sound weird if I use one wire of a stereo jack?bullwinkle wrote:Hi
check out the tutorial from adafruit, you might get some ideas....
http://learn.adafruit.com/stereo-3-7w-c ... und-system
Thanks!bullwinkle wrote:yes you are right, you will get either the left or the right side on the single speaker.
I read somewhere here on these forums about converting stereo to mono. I'll see if I can track it down and post back.
