I'm trying to run KeePass2 on Raspbian, but all I get is a segfault. It's a stock version installed via apt-get.
pi@raspberrypi ~ $ keepass2
Stacktrace:
at System.Drawing.Font.CreateFont (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x00147>
at System.Drawing.Font..ctor (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0007f>
at System.Drawing.Font..ctor (string,single,string) <0x00057>
at (wrapper remoting-invoke-with-check) System.Drawing.Font..ctor (string,single,string) <0xffffffff>
at System.Drawing.SystemFonts.get_DefaultFont () <0x0007b>
at System.Windows.Forms.Theme..ctor () <0x00033>
at System.Windows.Forms.ThemeWin32Classic..ctor () <0x00013>
at System.Windows.Forms.ThemeVisualStyles..ctor () <0x00013>
at System.Windows.Forms.ThemeEngine..cctor () <0x00083>
at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
at System.Windows.Forms.X11DesktopColors..cctor () <0x000bf>
at System.Windows.Forms.XplatUIX11..ctor () <0x001af>
at System.Windows.Forms.XplatUIX11.GetInstance () <0x00073>
at System.Windows.Forms.XplatUI..cctor () <0x00157>
at System.Windows.Forms.Application.EnableVisualStyles () <0x00023>
at KeePass.Program.Main (string[]) <0x00043>
at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
Debug info from gdb:
Cannot access memory at address 0x0
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0xb6618460 (LWP 2606)]
0xb6e827d0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Id Target Id Frame
2 Thread 0xb6618460 (LWP 2606) "cli" 0xb6e81700 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
* 1 Thread 0xb6f57000 (LWP 2605) "cli" 0xb6e827d0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 2 (Thread 0xb6618460 (LWP 2606)):
#0 0xb6e81700 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x00195a40 in mono_sem_wait ()
#2 0x000ea384 in ?? ()
#3 0x000ea384 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 1 (Thread 0xb6f57000 (LWP 2605)):
#0 0xb6e827d0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0xb6e82044 in __pthread_enable_asynccancel () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x00096e60 in ?? ()
#3 0x00096e60 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Did anyone manage to run this application? Are there any alternatives, or should I really leave it alone and convert my DB to version 1 - it seems like it has less exotic dependencies.
