brporter
Cannot install libegl1-mesa
Wed Aug 14, 2013 9:39 pm
I'm a Linux newb.
Trying to install libegl1-mesa-dev, but after a apt-get update/upgrade, libegl1-mesa is complaining that it requires an older version of libwayland0 (0.85.0-2) that what's installed (1.1.0-0rpi1).
I'm not really sure how to get out of this situation. Any suggestions?
Exact output from Pi:
pi@raspberrypi ~ $ sudo apt-get install libegl1-mesa-dev
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libegl1-mesa-dev : Depends: libegl1-mesa (= 8.0.5-4+deb7u2) but it is not going to be installed
                    Depends: libegl1-mesa-drivers (= 8.0.5-4+deb7u2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
 libegl1-mesa : Depends: libwayland0 (= 0.85.0-2) but 1.1.0-0rpi1 is to be installed
                Recommends: libegl1-mesa-drivers but it is not going to be installed
Thanks in advance!
Bryan
