kemnet
Powering up monitor and keyboard on pi
Sat Aug 10, 2013 1:07 am
Hello All
I'm a beginner trying to set up my raspberry pi. It boots fine i believe (im using NOOBS) however, my keyboard does not work if the monitor is plugged in. If i unplug the monitor and press the arrow keys it works. But if i plug back the monitor...keyboard is dead again. I am trying to wonder if this is a power or pi problem since the monitor doesnt really draw power from the pi so why should the keyboard not work (correct me if im wrong).
Also i have tried with various chargers and each of them behave differently, some just reboot to the multicolor screen and some others never power the keyboard (monitor or no monitor). I got a charger...5v 2000ma. but again that one doesnt let monitor and keyboard work simultaneously. Would like if someone could recommend a charger or preharps let me know if my Pi is broken.
Thanks .
Any help will be appreciated
gsh
Re: Powering up monitor and keyboard on pi
Sat Aug 10, 2013 5:30 am
How do you know it is working without the monitor plugged in?
Have you tried pressing 1, 2, 3, 4 on the keyboard to change video modes? I assume you're using HDMI?
Have you tried changing any hdmi config.txt options?
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
kemnet
Sat Aug 10, 2013 10:32 am
hello, thanks for the quick respond.
If u remember when u run noob for the first time u get a list of operating systems u can select,i can only cycle thru them using my keyboard when the moonitor is unplugged.i hav edited the config fiile accordiing to this link
http://www.makeuseof.com/tag/three-ways ... tor-or-tv/
because my monitor is not HDMI but rather i have an adapter.
