chuco61
Video output with push button advance
Thu Aug 08, 2013 4:00 am
I am a super noob and just bought my first Raspberry Pi B.
I am working on an art project where i have several avi video clips each 10 seconds in length. I want the user to be able to press on a push-button switch to advance to the next clip. I dont need any UI that the user will work with; simply push a button to view the next slide. Ideally i'd like to have the clips displayed through a projector.
Where do i start? I am here to learn!
Thanks in advance, im super stoked to start working with this new toy!! :D
PiGraham
Re: Video output with push button advance
Thu Aug 08, 2013 5:38 am
http://omxplayer.sconde.net/
Omxplayer works with keyboard controls.
If you don't want a normal keyboard you could wire a few buttons to the controller board from a usb keyboard, or use gpio-keys to generate keyboard input from gpio inputs connected to buttons.
I'm not sure what constitutes "next chapter".
KenT
Thu Aug 08, 2013 5:54 am
Pi Presents, see sig. Use mediashow with progress=manual Wire a button between the Next/Down GPIO input and 0 volts. Advancing from GPIO is all programmed into the application. You can get rid of the Loading... messages by editing resources.cfg
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
chuco61
Thu Aug 08, 2013 3:46 pm
wow!
Both of these options look really helpful. I think im going to play with the Pi Presents later this evening.
Thanks a lot! :P
chuco61
Fri Aug 09, 2013 11:47 pm
This Pi Presentation looks amazing as i am reading the manual and readme.
Since im so new to this, do i first need to load Raspbian onto my RPi as an operating system, then load in pi presentation as i would any other application?
Thanks again for the help and the "hand holding" :?:
