ITDiscovery
Python Code to upload a file to Google Drive
Thu Aug 08, 2013 12:09 am
I needed an easy way to get my KML (Map Track files) up to Google Maps....Google makes it easy by making an easy association for files that end in "KML" and have the MIME type of 'application/vnd.google-earth.kml+xml'.
Upload the file and click on it, and it quickly displays your track. Wonderful!! Just want I needed!! Now how to get the file there:
You need to get the gdata-python-client via "sudo apt-get install python-gdata"
The code below sends one file up to Google Drive. It must be provided a userid and password for your Google account, and it currently defaults to "My Tracks" and can only manually do jpegs....or if you hack the code, KML files....working on that...
#! /usr/bin/python
# Written by Peter Nichols to copy files to Google Drive. http://www.itdiscovery.info
# Sample file from http://planzero.org/blog/2012/04/13/uploading_any_file_to_google_docs_with_python
# Desired feature to grab all the kml/jpg files on the directory and dump them at once
# License: GPL 2.0
import sys, time, os.path, argparse
import atom.data, gdata.client, gdata.docs.client, gdata.docs.data
parser = argparse.ArgumentParser(description='Python script that KML files and uploads them to Google Drive.')
parser.add_argument('-u','--username', help='-u --username. Google Drive Username to Login as. Required!',required=True)
parser.add_argument('-p','--password', help='-p --password. Google Drive Password to Login as. Required!',required=True)
parser.add_argument('-l','--location', default='My Tracks', help='-l --location. [My Tracks] Google Drive Directory to store the KML files.',required=False)
parser.add_argument('-f','--filename', help='-f --filename The [directory and] file name for the KML file.',required=True)
args = parser.parse_args()
username = args.username
password = args.password
collection = args.location
filename = args.filename
fhandle = open(filename)
file_size = os.path.getsize(fhandle.name)
# Manually associate the file type...Magic too much of a pig
file_type='image/jpeg'
#file_type = 'application/vnd.google-earth.kml+xml'
docsclient = gdata.docs.client.DocsClient(source='RPi Python-GData 2.0.17')
# Get a list of all available resources (GetAllResources() requires >= gdata-2.0.15)
print 'Logging in...',
try:
    docsclient.ClientLogin(username, password, docsclient.source);
except (gdata.client.BadAuthentication, gdata.client.Error), e:
    sys.exit('Unknown Error: ' + str(e))
except:
    sys.exit('Login Error, perhaps incorrect username/password')
print 'success!'
# The default root collection URI
uri = 'https://docs.google.com/feeds/upload/create-session/default/private/full'
print 'Fetching collection ID...',
try:
   resources = docsclient.GetAllResources(uri='https://docs.google.com/feeds/default/private/full/-/folder?title=' + collection + '&title-exact=true')
except:
   sys.exit('ERROR: Unable to retrieve resources')
# If no matching resources were found
if not resources:
   sys.exit('Error: The collection "' + collection + '" was not found.')
# Set the collection URI
uri = resources[0].get_resumable_create_media_link().href
print 'success!'
# Make sure Google doesn't try to do any conversion on the upload (e.g. convert images to documents)
uri += '?convert=false'
#resources = docsclient.GetAllResources(uri='https://docs.google.com/feeds/default/private/full/-/folder?title=' + collection + '&title-exact=true')
print 'Starting uploading of file...',
# Create an uploader and upload the file
uploader = gdata.client.ResumableUploader(docsclient, fhandle, file_type, file_size, chunk_size=1048576, desired_class=gdata.data.GDEntry)
new_entry = uploader.UploadFile(uri, entry=gdata.data.GDEntry(title=atom.data.Title(text=os.path.basename(fhandle.name))))
print 'success!'
I'll be working on a multiple upload/batch ability and have it discern (by command line) the file type....the MAGIC libraries are kinda broken on RPi (I couldn't get it to work, and I just need one or two file types)...any help there would be welcome.
Any other suggestions??
-petern
LetHopeItsSnowing
Re: Python Code to upload a file to Google Drive
Thu Aug 08, 2013 11:46 am
This might be simpler to use grive to get stuff onto google drive. Its a utility to sync a folder on your pi with google drive. Run it every hour (or few minutes) and it will sync files on your pi and google drive.
Check out my post for info on how to set it up.
http://www.stuffaboutcode.com/2013/03/r ... grive.html
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
ITDiscovery
Fri Aug 09, 2013 2:24 am
Yup...saw that, a good utility except that my RPi spends alot of it's time headless and network-less. Not sure that will work, so this pretty lightweight (the python-gdata libraries are pretty small) python script does turn the trick very well...
Anyone with suggestions on improving or mod-ing the code to a specific need, I'd be happy to take a look. IMHO this also give a pretty good primer on connecting to Google Drive for other applications.
#! /usr/bin/python
# License: GPL 2.0
parser.add_argument('-f','--filename', help='-f --filename The file name/directory for the KML file.',required=True)
parser.add_argument('-s', '--single', default=0, type=int, help= '-s --single [1] A single file [0] or all files [1] of that type in the directory', required=False)
parser.add_argument('-m','--mimetype', default='jpg', choices=['kml','jpg','txt','csv','mpg','mp4'],help='-m --mimetype [jpg] The file type of the files: kml, jpg, txt, csv, mpg, mp4',required=False )
targetdir = args.filename
single = args.single
ftype = args.mimetype
if ftype == 'jpg':
    file_type = 'image/jpeg'
elif ftype == 'kml':
elif ftype == 'txt':
    file_type = 'text/plain'
elif ftype == 'csv':
    file_type = 'text/csv'
elif ftype == 'mpg':
    file_type = 'audio/mpeg'
elif ftype == 'mp4':
    file_type = 'video/mp4'
#Start the Google Drive Login
try:
except:
print 'success!'
print 'Fetching Collection/Directory ID...',
try:
except:
if not resources:
print 'success!'
if single==1:
   #Loop through directory name in arguments for all the file types
   for filer in os.listdir(targetdir):
    if filer.endswith(ftype):
         print 'Uploading ', filer,'.....',
         fhandle = open(filer)
         print 'success!'
         continue
    else:
         print 'Skipping',filer,'.'
         continue
else:
    print single
    #fhandle = open(targetdir)
    #file_size = os.path.getsize(fhandle.name)
    #print 'Uploading ', targetdir,'....'
    #uploader = gdata.client.ResumableUploader(docsclient, fhandle, file_type, file_size, chunk_size=1048576, desired_class=gdata.data.GDEntry)
    #new_entry = uploader.UploadFile(uri, entry=gdata.data.GDEntry(title=atom.data.Title(text=os.path.basename(fhandle.name))))
    #print 'success!',
print 'Done!'
ITDiscovery
Sun Sep 01, 2013 9:19 pm
Whoops!! Never undocumented the single mode code...
#! /usr/bin/python
# License: GPL 2.0
if ftype == 'jpg':
try:
except:
print 'success!'
try:
except:
if not resources:
print 'success!'
if single==1:
         print 'success!'
         continue
    else:
         continue
else:
    print 'success!',
print 'Done!'
Return to “Python”
Who is online
Users browsing this forum: No registered users and 21 guests
