kingoslo
WIFI, cant get RTL8188CUS to work
Tue Aug 06, 2013 8:47 pm
Hello there,
I bought a cheap wifi dongle which has the RTL8188CUS.
A very very long thread on this forum had multiple users whom guaranteed it would work. I have wasted $100 on dongles which did not work, and I was finally fed up.
The project of getting wifi started about a year ago, and it still does not work.
I have tried all the configurations in the universe, I just want to beg somebody whom is knowledgable to walk through the process with me step by step, and correct the problem.
This is the only prositive sign I have:
 $ susb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 005: ID 09da:000a A4 Tech Co., Ltd Optical Mouse Opto 510D
Bus 001 Device 006: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 007: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
I had to set this in interfaces, otherwise the Pi was complaining it couldnt read the file at boot-time, no matter what I did to it:
$ sudo nano /etc/network/interface
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
I hope you can help me, nice and slow, to get this to work. I cannot wait another year. Usually I reformat the SD card every time I mess something up. And buy a new dongle, when the tutorial fails. I am giving up that approach. Hope you can help.
Thank you for your time.
Kind regards,
Marius
MrEngman
Re: WIFI, cant get RTL8188CUS to work
Wed Aug 07, 2013 8:04 am
If it said it couldn't read the /etc/network/interfaces file then you put something in it than it did not like.
Take a look here for some simple instructions http://www.fars-robotics.net/
MrEngman
kingoslo
Wed Aug 07, 2013 4:20 pm
MrEngman wrote:If it said it couldn't read the /etc/network/interfaces file then you put something in it than it did not like.
MrEngman
Thank you so much for this help! It works without wpa supplicant, when i put the ssid and wpa directly in the inferfaces data.
This is my current interfaces data:
auto lo
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "XXXXXXXXXXX"
wpa-psk "XXXXXXXXXXX"
Are you able to suggest how to alter this file to get static IP?
Kind regards,
Marius
MrEngman
Wed Aug 07, 2013 4:52 pm
To set up a static IP for the wifi you will need to alter the /etc/network/interfaces file to something like the following
auto lo
allow-hotplug wlan0
iface wlan0 inet static  <-- change from dhcp to static
address 192.168.1.3      <-- add address, netmask, network and gateway
netmask 255.255.255.0
network 192.168.1.0
gateway 192.168.1.1
You will need to set the address, network and gateway settings to suit your own network.
address will be the static IP assigned to the wifi, and gateway is generally the router's IP.
MrEngman
kingoslo
Wed Aug 07, 2013 5:42 pm
Thanks Engman,
That was fantastic :D
Kind regards,
Marius
MrEngman
Wed Aug 07, 2013 5:49 pm
kingoslo wrote:Thanks Engman,
Kind regards,
Marius
Glad to be of help. Have fun with your Pi.
MrEngman
