Hello there,
Once I apply voltage across the terminals of the RPi, the PWR led lights up, but nothing else blinks, or seem to happen at all.
I get no picture on the screen, the keyboard shows no LEDS light up, and does not respond to number presses 1-4, or any of the lock keys (num lock, caps lock etc). It looks like the thing does not respond.
TP1 measures 5.108V relative to GND. TP2 measures 0V relative to GND. The RPi draws stable 106.52mA from the power supply.
I am trying to boot from a sandisk 32GB SD card with NOOBS unzipped onto it. The file system is FAT32. The RPi did seem to work before I formated the SD card using gparted, and unzipped NOOBS.zip onto it. This tells me that probably there is something wrong with the way the SD card is set up, but I have followed the NOOBS guide to the letter (at least as far as I can tell), and it doesn't work.
What is going on?
Kind regards,
Marius
