OK, starting from the beginning. Have you loaded lirc_rpi either by adding it to /etc/modules or modprobing it? I am assuming you'r using a gpio receiver, is this correct? I'm not sure about the tutorial you're using but I KNOW this one works http://forum.stmlabs.com/showthread.php?tid=5549
Aiutatemi
I have the exact same problem, I did the same configuration guide, but use the IR you see in this kit: http://www.banggood.com/Electronics-Sta ... 35333.html
i have a problem on my PI3
when i try to rerecord my remote of air condition " it toke so long " the show this
" check troubleshooting in irrecord manpage . "
any help !!?
I had the same issue. I was trying to run the irrecord command in /etc/lircd/lircd.conf.d folder as this is where the guide i was following left me at that point. What solved it for me was to run the command after having stopped the lircd service from my home folder.
