michael.warren
HDMI Drops
Mon Jul 29, 2013 10:30 pm
I just finished a video looper project that plays video files the Pi finds on usb storage using omxplayer. Here's the thread where I asked a few questions about the code...http://www.raspberrypi.org/phpBB3/viewt ... 0&p=383559
The project works wonderfully except for one thing... every time omxplayer starts a new clip, the HDMI signal drops out for half a second. This causes the tv to refresh the input, so I lose sound for a few seconds, and the ugly source identification appears on the screen (see attachment). I've tried this on two separate tvs, and the same problem occurs on HDMI only. There are no problems on the composite output.
I just export H.264 files directly from adobe premiere, and the pi plays them beautifully! Omxplayer plays 1080p @ 30Hz without any hiccups during playback. My omxplayer code is below... any suggestions to eliminate this interruption?
#!/bin/bash
while true; do
  cd "/media/PIDRIVE"
  set -- *.mp?
  for i;do
  omxplayer -r -o hdmi "$i"
  done
done
mandelbrot
Re: HDMI Drops
Thu Jan 23, 2014 7:10 am
Michael did you found a solution meanwhile?
I have the same problem and it would be nice if you could give me a hint!
cheers
gkreidl
Re: HDMI Drops
Thu Jan 23, 2014 10:41 am
mandelbrot wrote:Michael did you found a solution meanwhile?
cheers
Don't use the "-r" option if you want to avoid that.
Minimal Kiosk Browser (kweb)
michael.warren
Re: HDMI Drops
Sun Jan 26, 2014 7:16 pm
No :| Let's see if gkreid's solution works
gkreidl wrote: Don't use the "-r" option if you want to avoid that.
I'll try that... just curious as to what that argument means. I've found very little relating to omxplayer's arguments.
