rterren
Re: networked mp3 player with lcd display
Mon Apr 23, 2012 1:39 am
I just started reading about this project today while poking around some Arduino posts.  I am a noob and have never tried anything like this before, so please excuse the question if I daft, I did search the forums and came up with nothing.
My question is, could the Raspberry Pi be used as a wired network MP3 player, connecting to say a shoutcast or icecast server, to play an MP3 stream as a Line level output (or adjustable headphone volume), all while displaying some MP3 song data on an attached LCD multi-line display?
I know this is not trivial, I am thinking if the hardware is able to do something like this and if there is a compatible LCD multi-line display available this may be a fun project for me to work towards.  I did it previously with a set top box from Patriot Memory Systems, but there was no way to attach an LCD display, and it cost alot more.
I figure I would use something like madplayer or mplayer and the alsa package.  A "stage 2" bonus would be if there is a physical button that I could tap to cycle from one pre-programmed IP to another so I could switch streams.
Ron
lesliew
Mon Apr 23, 2012 2:03 am
Ron
Here's an idea for a really cheap USB display and some instructions to get it up and running.  Those instructions should work fine for the Pi.
http://forum.doozan.com/read.php?2,2435
You just need to find a way to capture the song data from whatever music service you decide to use and write it out to the display.
bredman
Mon Apr 23, 2012 10:44 am
For information on multi-line LCD displays, have a look at
http://www.raspberrypi.org/for.....lcd-screen
rterren
Tue Apr 24, 2012 3:33 am
Thanks very much now if I could actually get a board I would be all set lol...I was told they are back ordered until August!
