I have been modifying the /sound/arm/bcm2835-pcm.c file and compiled the kernel and modules, and now the raspberry can play audio files up to 192/24.
Part of the original file I manipulated:
<linux/interrupt.h>
#include <linux/slab.h>
#include "bcm2835.h"
/* hardware definition */
static struct snd_pcm_hardware snd_bcm2835_playback_hw = {
.info = (SNDRV_PCM_INFO_INTERLEAVED | SNDRV_PCM_INFO_BLOCK_TRANSFER |
SNDRV_PCM_INFO_MMAP | SNDRV_PCM_INFO_MMAP_VALID),
.formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S16_LE,
.rates = SNDRV_PCM_RATE_CONTINUOUS | SNDRV_PCM_RATE_8000_48000,
.rate_min = 8000,
.rate_max = 48000,
.channels_min = 1,
.channels_max = 2,
.buffer_bytes_max = 128 * 1024,
.period_bytes_min = 1 * 1024,
.period_bytes_max = 128 * 1024,
.periods_min = 1,
.periods_max = 128,
};Code: Select all
.formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S24_LE | SNDRV_PCM_FMTBIT_S32_LE,
.rates = SNDRV_PCM_RATE_CONTINUOUS | SNDRV_PCM_RATE_8000_192000,
.rate_min = 8000,
.rate_max = 1920000,
.channels_min = 1,
.channels_max = 2,
.buffer_bytes_max = 256 * 1024,
.period_bytes_max = 256 * 1024,
.periods_min = 1,
.periods_max = 256,
};All the 24 bit files 88.1 96 qnd 192 plays fine, whereas the lower resolution files 16 bit at 44.1 and 48 kHz plays, but with some distortion.
If I change this line to: .formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S16_LE it plays everything at 16 bit
If I change this line to .formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S24_LE it only produces noise
If I change this line to .formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S24_3LE it only produces noise
So there seems to be a couple of questions:
1. why does it only use the the last option in the .formats line?
2. why can't it use the 24 bits format?
3. The change from 16 and 24 bit to 32 bit when playing will it negatively affect the sound quality. I cant hear any difference, but my equipment is not so good.
Steen
Here is the output when playing a 44.1/16 flac file
cat /proc/asound/card0/pcm0p/sub0/hw_params
access: RW_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 442
buffer_size: 1768
here when 192/24 bit flac is played:
format: S32_LE
subformat: STD
channels: 2
rate: 192000 (192000/1)
period_size: 1920
buffer_size: 7680
PS: I'm using microcore linux
