Museste
Descent Compile Error
Sun Jul 28, 2013 3:43 am
Greetings
Im trying to compile Descent. When I compile I get the following error
D1X-Rebirth: LittleEndian machine detected
D1X-Rebirth: building with OpenGL ES
D1X-Rebirth: including SDL_mixer
using Raspberry Pi vendor libs in /opt/vc
scons: done reading SConscript files.
scons: Building targets ...
Compiling arch/ogl/gr.c ...
arch/ogl/gr.c:54:22: fatal error: GLES/egl.h: No such file or directory
compilation terminated.
scons: *** [arch/ogl/gr.o] Error 1
scons: building terminated because of errors.
I belive I have all the required packages, what have I done wrong?
You guys rock
Re: Descent Compile Error
Sun Jul 28, 2013 5:39 am
Do you have libgles1-mesa-dev installed?
Museste
Sun Jul 28, 2013 9:16 am
Whats the best way to go about that? I used the following from a previous post based on compiling Hurrican
[quote]apt-get install libegl1-mesa libegl1-mesa-dbg libegl1-mesa-dev libegl1-mesa-drivers libegl1-mesa-drivers-dbg libgles1-mesa libgles1-mesa-dbg libgles1-mesa-dev libgles2-mesa libgles2-mesa-dbg libgles2-mesa-dev[/quote]
I got the following
[quote]The following packages have unmet dependencies:
libegl1-mesa : Depends: libwayland0 (= 0.85.0-2) but 1.1.0-0rpi1 is to be installed
libegl1-mesa-drivers : Depends: libwayland0 (= 0.85.0-2) but 1.1.0-0rpi1 is to be installed
E: Unable to correct problems, you have held broken packages.[/quote]
Will tackle this again tommorow :-) Must resist temptation to stay up all night on the pi.
Museste
Sun Jul 28, 2013 9:18 am
Sorry for the formatting, still learning how to use the forum
Return to “Gaming”
