I'm trying to set up scanning on the Pi, and I installed saned. To test it, I ran the command scanimage, which is a command-line tool to capture an image. If I run it as root, it scans successfully (I can hear the scanner operating), but if I run it as any other user, e.g. the user saned, I get this error:
scanimage: open of device pixma:04A91734 failed: Access to resource has been deniedI've googled the error, but all the help on the internet pertains to operating systems other than Raspian, so I couldn't apply any of it.
Any ideas?
Edit: the same problem appears to be here: http://www.raspberrypi.org/phpBB3/viewt ... 2&p=376936 but the OP didn't say how they fixed it.
Another edit: this bug in sane looks like it could be the cause: https://bugs.launchpad.net/ubuntu/+sour ... bug/180794
