Joe Schmoe
How to get email working on Pidora
Tue Jul 23, 2013 2:17 pm
Running Pidora installed via NOOBS.
Noticed that sendmail (and friends) is installed by default and seems to be working - but doesn't work. Note, BTW, that sendmail and friends is *not* installed/configured by default in Raspbian, and it is a frequent forum query to ask how to get it working (often in the context of "cron" - that is, people wonder why their cron jobs aren't working - and the real answer is "because they can't see the error messages - because email isn't configured." - but I digress...).
Anyway, back to Pidora... It seems that it (email) works (sort of) for local users, but fails (with the usual sort of error messages - cannot contact server, etc) when sending offsite.
Has anyone gotten this to work?
P.S. Also, it seems cron is disable by default in Pidora. How to turn that on?
Joe Schmoe
Re: How to get email working on Pidora
Tue Jul 23, 2013 3:54 pm
A couple of added notes:
1) It is funny that Raspbian comes with cron on, but email not - and Pidora is just the opposite (except, of course, for the fact that email doesn't work - but at least it is there...)
2) To turn cron on in Pidora: service crond start
(Not sure yet if this persists across reboot...)
ruggerio
Wed Jul 24, 2013 6:36 am
beware of systemd from Fedora 18 on.
systemctl is-enabled crond.service --> checks, if cron will be started on boot or not
systemctl enable crond.service --> enables it for start, if its not done.
systemctl disable crond.service --> disables it for start, manual start will go anyway
systemctl start crond.service --> manual start of cron
systemctl status crond.service --> gives status information about it
For mail:
ouch, i do not remember removing sendmail, as i use postfix, which is quite simpler to configure. Using Postfix will send mails within a few minutes.
Cheers,
Roger
Return to “Pidora / Fedora”
