chrisrpriceuk
Raspbmc slows internet connection
Sun Jul 21, 2013 3:20 am
Hi all,
I'm having a strange problem with my raspbmc install.
When I try to stream or download anything, my entire network / internet connection seems to ground to a halt.
I have a fibre broadband connection, so bandwidth generally isn't an issue.
what seems to cause the problem? Youtube streaming continuously buffering and failing, airplay from an iphone / ipad buffers and failing too.
It get's to the point where I need to pull the plug on the Pi to free anything up.
Even the remote stops working when I get these symptoms.
Any thoughts?
Chris
Paul Webster
Contact: Twitter
Re: Raspbmc slows internet connection
Sun Jul 21, 2013 7:47 am
You could try running Wireshark on one of the computers in the same LAN to try to see what is going on.
drgeoff
Sun Jul 21, 2013 12:51 pm
The other clients mentioned are an iphone and an ipad, both of which presumably connect by Wi-Fi. Is the accused RPi also connected by Wi-Fi to the router or does it have a wired connection?
And what remote stops working?
Return to “Media centres”
