Sat Apr 21, 2012 6:51 pm
ThePunisher1024 said:
So we have a 1gb partition for the linux install, which is all the files that the Debian/Fedore/Linux deployment needs to function, then we also have a swap partition which is essentially your page file space (any reccomendations on size of this or does it size itself to a default size?).
I am assuming when installed, size that you can write to yourself, like installing applications and stuff, is to the 1gb linux bit? Or does the partition appear as one partition exclusively for the linux install then another partition for the remaining space?
With the default partitioning in place the amount of free space you have is the space leftover in the 1 GB or so root "/"partition. To be able to use the rest of the space on your SD card that's not included in the partition you either have to create additional partitions or resize your root partition.
