Do you know why I have these errors when running a "yum update"?
Is there a solution ?
# yum update
---> Package perl.armv6hl 4:5.16.2-239.fc18 will be updated
--> Processing Dependency: perl = 4:5.16.2-239.fc18 for package: 1:perl-parent-0.225-239.fc18.noarch
--> Processing Dependency: perl = 4:5.16.2-239.fc18 for package: perl-Carp-1.26-239.fc18.noarch
---> Package pyxattr.armv6hl 0:0.5.1-2.fc18 will be installed
---> Package systemd-python.armv6hl 0:195-7.fc18 will be installed
--> Finished Dependency Resolution
Error: Package: 12:dhclient-4.2.4-23.P2.fc18.armv6hl (@anaconda-0/bluesky)
Requires: libisc-export.so.92
Removing: 32:bind-libs-lite-9.9.2-5.P1.fc18.armv6hl (@anaconda-0/bluesky)
libisc-export.so.92
Updated By: 32:bind-libs-lite-9.9.3-3.P1.fc18.armv6hl (pidora-updates)
Not found
Error: Package: perl-Carp-1.26-239.fc18.noarch (@anaconda-0/bluesky)
Requires: perl = 4:5.16.2-239.fc18
Removing: 4:perl-5.16.2-239.fc18.armv6hl (@anaconda-0/bluesky)
Updated By: 4:perl-5.16.3-244.fc18.1307170805kf.armv6hl (pidora-updates)
perl = 4:5.16.3-244.fc18.1307170805kf
Requires: libdns-export.so.95
libdns-export.so.95
Not found
Error: Package: 1:perl-parent-0.225-239.fc18.noarch (@anaconda-0/bluesky)
You could try using --skip-broken to work around the problem
