Peterleroux
Ethernet USB dongle - Asus ASIX AX88772B
Wed Jul 17, 2013 5:42 am
this is just to confirm that the USB dongle as supplied with Asus Zenbooks works on the Raspberry Pi Model A without any configuration required.
FTrevorGowen
Re: Ethernet USB dongle - Asus ASIX AX88772B
Thu Jul 18, 2013 2:32 pm
Peterleroux wrote:Hi,
Thank you, that's useful to know - perhaps you could add it to the wiki (http://elinux.org/RPi_VerifiedPeriphera ... t_adapters) . FWIW, you might also be interested in this thread of mine:
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=45718
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Peterleroux
Fri Jul 19, 2013 11:23 am
Will do Trevor.
These seem pretty pricey as replacement parts, but I got one with my new laptop, so it's nice to know it works with the pi, given how spotty support is for USB->ethernet dongles generally
jmprince80
Fri Sep 27, 2013 8:51 pm
Hi, I have a ASIX AX88772A, and just to warn people, this adaptor does not seem to play well with a Pi model B running the latest raspbian.
Initially, everything seems OK, but upon returning to check some hours later, the Pi is invariably locked up, cannot access via USB/Hdmi or the onboard ethernet.
Quite annoying as I bought two of these from ebay.
Nothing in syslog either...
If anyone else has had a similar problem and managed to sort it out then please let me know.
peter0pi0per
Tue Mar 25, 2014 3:42 am
What a difference a letter makes... I am using an AX88772B for the past day or so on an rpi configured as a router. This device came with a zenbook. I ran speedtest.net and it supported by ISP link @ 30 mb/s, IPv4 and IPv6. no crash or glitch of any kind.
root@raspberrypi:/etc/bind# lsusb
Bus 001 Device 004: ID 0b95:7e2b ASIX Electronics Corp. AX88772B
Bus 001 Device 005: ID 04f2:0112 Chicony Electronics Co., Ltd KU-8933 Keyboard with PS/2 Mouse port
root@raspberrypi:/etc/bind# uname -a
Linux raspberrypi 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/Linux
I have another cheapo adapter, and it crashes the pi after a few minutes, but the Asus one works perfectly. clearly ymmv.
