marian42
Setting the correct time
Mon Jul 15, 2013 2:18 pm
i want to set the correct time on my Pi for a datalogging project. It has a permanent internet connection.
I tried ntpd, tcselect, putting my timezone in /home/pi/.config and rebooting. It is always exactly 10 minutes and some hours too late.
It is 16:16 and the Pi displays 13:26. Errors less than a few minutes are no problem for me.
How can I make the Pi get the correct time on startup?
RaTTuS
Contact: Twitter YouTube
Re: Setting the correct time
Mon Jul 15, 2013 2:30 pm
set your timezone
sudo raspi-config
as to the weird 10 mins or so ...
are you sure your other sources are correct
the clock should auto correct when it's connected to the internet
Covfefe
marian42
Mon Jul 15, 2013 5:44 pm
Okay so I set the timezone and it is now closer to the actual time.
The date command says that it's 18:53 CEST while the actual CEST is 18:43.
crazyskeggy
Tue Jul 16, 2013 6:31 pm
What distribution are you using? I know Raspbian get's it's time from the internet, and all others should, too.
Running a Model B (256MB RAM) with Raspbian (in NOOBS 1.3) and a Model B (512MB RAM) with OpenELEC + CEC (No NOOBS, as it breaks CEC)
marian42
Tue Jul 16, 2013 6:38 pm
I'm using Raspian.
crazyskeggy
Wed Jul 17, 2013 7:24 am
Check your internet connection - if anybody knows how to manually update NTP (time server), then it would be useful to know.
Wed Jul 17, 2013 8:21 am
crazyskeggy wrote:Check your internet connection - if anybody knows how to manually update NTP (time server), then it would be useful to know.
You can check that NTP is set up correctly with ntpq -p
pi@raspi3 ~ $ ntpq -p
     remote           refid      st t when poll reach   delay   offset  jitter
*myntpserver     94.23.228.130    3 u   61   64    1    0.509   -1.523   1.447
That is showing that my pi is synchronised to "myntpserver" which got its time from 94.23.228.130. The last update was 61 seconds ago, it checks every 64 seconds. The server takes about 0.509ms to reply, is 1.523ms different to the current clock and varies by 1.447ms.
The list of servers to use is held in /etc/ntp.conf. It is usually set to a number of server names, each of which redirects to a set of servers in a round-robin list.
dspolleke
Wed Jul 17, 2013 9:53 am
The way NTP works is that it does not make the clock jump to the correct time but speeds up the cpu / hardware clock or slows it down. If i recall correctly the pi does not have a built in "clock" device and you need ntp to adjust the time constantly...
if you would like to set te time at startup FIRST configure the ntp deamon in /etc/ntpd.conf
make sure you have a reachable NTP server
let's say nl.pool.ntp.org (for i live in the Netherlands) but if you set up a local ntp server that is even better..
make sure ntp allows the ntp server to help you out... (adjust to match)
restrict 192.168.1.0 mask 255.255.255.0 nomodify notrap
next write a small script like this
#!/bin/bash
TIMESERVER=nl.pool.ntp.org
/etc/init.d/ntp stop
ntpdate $TIMESERVER
/etc/init.d/ntp start
Have it started via or just add the above to /etc/rc.local
more reading about NTP
http://www.ntp.org/ntpfaq/NTP-s-def.htm
Please read: http://www.biblegateway.com/passage/?search=Matthew+7%3A7&version=NIV
Use loads of sunscreen, use the search, be elaborate in questions, paste commands and error messages, and remember google is your friend!
Wed Jul 17, 2013 10:32 am
dspolleke wrote:The way NTP works is that it does not make the clock jump to the correct time but speeds up the cpu / hardware clock or slows it down. If i recall correctly the pi does not have a built in "clock" device and you need ntp to adjust the time constantly...
#!/bin/bash
ntpdate $TIMESERVER
Actually ntpdate is deprecated and shouldn't really be used any more. ntpd can provide everything that ntpdate did, and more.
ntpd is given the "-g" flag at start-up, which means it is allowed to make set the time directly, just once, if it is over 1000 seconds out. This replaces the need for ntpdate.
marian42
Wed Jul 17, 2013 1:33 pm
ntpq -p returns this:
pi@raspberrypi ~ $ ntpq -p
ntpq: read: Connection refused
But the Pi does have a working internet connection. I just tested it with the browser.
There is no /etc/ntp.conf but a ntpd.conf. I made a copy of it so now there are both. But the ntpq -p command still has no success.
Wed Jul 17, 2013 3:00 pm
marian42 wrote:ntpq -p returns this:
Ok, important question. Are you running a Raspbian system, or one of the other Linux distros?
marian42
Wed Jul 17, 2013 3:28 pm
I'm running Raspbian.
Wed Jul 17, 2013 3:47 pm
marian42 wrote:I'm running Raspbian.
Very odd then. You should have an ntp.conf file and it should "just work".
RaTTuS
Wed Jul 17, 2013 4:30 pm
either start again from a blank image
or try and uninstall ntp then reinstall it...
as /etc/ntp.conf should exist
Covfefe
Wed Jul 17, 2013 5:35 pm
RaTTuS wrote:try and uninstall ntp then reinstall it...
sudo apt-get purge ntp
sudo apt-get update
sudo apt-get install ntp
The "purge" option will make sure that all traces of ntp are removed, including any configuration files. With the usual "remove" option, they are left behind so they can be used for any new version that gets installed.
marian42
Wed Jul 17, 2013 7:34 pm
I still get a connection refused error.
My raspberry pi is only two weeks old so the Raspbian image should be up to date.
FTrevorGowen
Wed Jul 17, 2013 8:12 pm
Like rpdom I've never had to do "anything special" for ntp to work for raspbian so, FWIW (and for reference) here's the contents of /etc/ntp.conf ...
# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
# Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
# You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example
# pool.ntp.org maps to about 1000 low-stratum NTP servers.  Your server will
# pick a different set every time it starts up.  Please consider joining the
# pool: <http://www.pool.ntp.org/join.html>
server 0.debian.pool.ntp.org iburst
server 1.debian.pool.ntp.org iburst
server 2.debian.pool.ntp.org iburst
server 3.debian.pool.ntp.org iburst
# Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
# details.  The web page <http://support.ntp.org/bin/view/Support/AccessRestrict
ions>
# might also be helpful.
# Note that "restrict" applies to both servers and clients, so a configuration
# that might be intended to block requests from certain clients could also end
# up blocking replies from your own upstream servers.
# By default, exchange time with everybody, but don't allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
# Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
# Clients from this (example!) subnet have unlimited access, but only if
# cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
# If you want to provide time to your local subnet, change the next line.
# (Again, the address is an example only.)
#broadcast 192.168.123.255
# If you want to listen to time broadcasts on your local subnet, de-comment the
# next lines.  Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
and ntpq - p reports ...
pi@raspigrey ~ $ ntpq -p
*diane.ensma.fr  131.188.3.221    2 u   19   64  377   34.773    0.922   5.370
+callisto.mysnip 130.149.17.8     2 u   13   64  377   54.417    4.743   4.532
+notary1.converg 192.53.103.104   2 u   57   64  377   52.559   -8.367   5.808
-rad.22pf.org    130.88.200.6     3 u   56   64   37   29.582   11.393   6.060
Exactly where are you? (O.K. I should be able to find the CEST timzone :-) but ...) just in case there's an issue with ntp servers "there". The only other thing that comes to mind is the possibility that your router's firewall (or other settings) is blocking ntp access (or something like that).
Trev
marian42
Wed Jul 17, 2013 8:24 pm
My ntp.conf looks just the same. I live in Germany which has only one timezone, the CEST.
FTrevorGowen
Wed Jul 17, 2013 8:36 pm
marian42 wrote:My ntp.conf looks just the same. I live in Germany which has only one timezone, the CEST.
It's too hot here :-), I should have recognised Central European Standard Time of course :oops:
Since my Pi(s) is (are) picking up an ntp server in FRance and I know Debian is well supported in Germany it's looking even more like a router/firewall issue. Unless your internet access if via a proxy server? (Which also could be blocking access/requests).
Sorry I can't be of more help.
Trev.
drgeoff
Wed Jul 17, 2013 11:16 pm
marian42 wrote:My raspberry pi is only two weeks old so the Raspbian image should be up to date.
Is that a clue that your SD card came pre-written with your RPi? If yes, I'm afraid it is no guarantee at all that the OS is up to date. On the other hand, if you flashed it yourself you will know which version of Raspbian wheezy you downloaded.
marian42
Wed Jul 17, 2013 11:29 pm
I downloaded the image myself via bittorrent from the official site.
The first line in ssh says: Linux raspberrypi 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv61
Is there a way to check if my router blocks the ntp connection?
