- play your music via AirPlay, via Chromecast, as an mp3 stream or locally on the RPi
- stream audio and some video to iTunes
- be controlled by remotes like Apple Remote on iOS, Retune/TunesRemote+ on Android or Remote for WP on Windows Phone
- be controlled via its web interface
- be controlled by any MPD client
- has support for audio files in most formats, internet radio and Spotify
- Add repository key
wget -q -O - http://www.gyfgafguf.dk/raspbian/forked-daapd.gpg | sudo apt-key add - - Add either of these lines to /etc/apt/sources.list:
(for stretch) deb http://www.gyfgafguf.dk/raspbian/forked-daapd/ stretch contrib
(for buster) deb http://www.gyfgafguf.dk/raspbian/forked-daapd/ buster contrib - Run sudo apt update and then sudo apt install forked-daapd
- Edit the configuration file (usually /etc/forked-daapd.conf) to suit your needs
- Start or restart the server: sudo service forked-daapd restart
- Wait for the library scan to complete. You can follow the progress with tail -f /var/log/forked-daapd.log
- If you are going to use a remote app, pair it by going to http://forked-daapd.local:3689/ and find the settings
Optional - how to add support for Spotify:
- Add key: wget -q -O - https://apt.mopidy.com/mopidy.gpg | sudo apt-key add -
- Add to /etc/apt/sources.list: deb http://apt.mopidy.com/ stable main contrib non-free
- Run sudo apt update and then sudo apt install libspotify-dev
- Restart forked-daapd and open http://forked-daapd.local:3689/ to enter Spotify credentials
- Check the log to see how it is working. It should start loading your playlists.
You can get the source from the github repository.
My modifications include the following (as of release 112):
- includes patch against timeouts
- includes misc patches (non apple players, ffmpeg/libav changes)
- configurable artwork file names
- additional artwork identification features
- compiled with FLAC and iTunes XML support enabled
- support for Remote 3.0
- includes a start/stop-script
- installed files are in their normal locations (so not in /usr/local)
- automatically installs required directories
- runs as root (so does not require adding users/groups manually and adjusting ownerships of folders)
- more complete dependency listing
- preference for album artist if it is available (release 8)
- bug fix for certain Airport Express models (release 9)
- bug fix for AirFoil Speakers (release 10)
- added support for internet radio with m3u (release 10)
- fixed fatal error when stopping player (release 11)
- m3u and iTunes playlist scanner improvements (release 12)
- improved compability with Hyperfine Remote for Android (release 13)
- speaker selection and m3u bug fixes (release 13)
- Shoutcast (icy) metadata support for internet radio (release 14)
- bug fix for playlists with only one item (release 14)
- updates for ffmpeg/libav (release 14)
- fix for Apple TV update 6.0 - thanks jmp909 (release 15)
- fix artwork memory leak (release 16)
- improved support for podcasts and compilations - thanks jmp909 (release 16)
- user can tell file scanner to ignore certain file types (release 16)
- adjustments for Remote 4, mainly play queue support (release 17)
- fix to support displaying metadata on non-Apple airplay devices (release 17)
- configurable library names (release 18)
- sorting changes/ignore article (release 18)
- fix for TunesRemote SE (release 18)
- force library rescan with .force-rescan (release 18)
- fix for the Retune remote on Android - thanks SquallyDoc (release 19)
- audiobook playlists (release 19)
- fix for AirBubble speakers (release 19)
- support for artwork in iTunes (release 20)
- fixed ffmpeg/libav logging (release 20)
- misc bug fixes (release 21)
- logging and documentation adjustments (release 22)
- autoselect AirPlay device if none selected (release 22)
- database upgrade fix (release 23)
- support for embedded artwork (release 24)
- config option to disable startup scan (release 25)
- config option for max volume (release 26)
- start/stop issues in Raspbmc fixed (release 26)
- better support for WMA files (release 26)
- better support for Remote for Windows Phone - thanks misenhower (release 27)
- Spotify support (release 28)
- fix for iTunes, so all relevant media shares will show up (release 28)
- stream from pipes (release 29)
- fix m3u scanning (release 30)
- faster scanning and support for init-rescan - thanks chme (release 31)
- Up Next queue editing and support for History - thanks chme (release 31)
- fixes for Seafile and XBMC (release 32)
- drop libevent 1 dependency, version bump to 21 (release 33)
- fix for library permission changes (release 33)
- DAAP cache for much improved performance (release 34)
- play queue/Up next improvements - thanks chme (release 34)
- options to tweek database performance - thanks chme (release 34)
- support for .pls playlists (release 34)
- support for LastFM scrobbling (release 34)
- artwork cache - thanks chme (release 37)
- misc bug squashing (release 38)
- fix for iTunes 12.1 (release 39)
- support for MPD - thanks chme (release 40)
- support for smart playlists - thanks chme (release 40)
- playlist and internet stream overhaul (release 40)
- support for more MPD commands, e.g. idle - thanks chme (release 42)
- fix db lock, m3u and Windows Phone bugs (release 43)
- improvements for Spotify and MPD (release 43)
- audiobook improvements (release 44)
- refactor queueing (thanks chme) and transcoding (release 45)
- mp3 streaming (release 45)
- systemd startup files for Jessie (release 46)
- fix database locking and freeze issues (release 47)
- fix ipv6 problem and improve Spotify artwork handling (release 48)
- fix internet radio stuttering problem (release 49)
- faster MPD library loading and more commands supported (release 49)
- Chromecast support (release 49)
- fix local audio problem (release 50)
- local audio remake and fix for playlist orders (release 51)
- keep output devices selected, also after power cycle (release 52)
- support for Monkey's audio (release 53)
- support for Pulseaudio (release 54)
- fixes for Pulseaudio and tvOS10 (release 55)
- perf. improvements and support for browserbased clients (release 56)
- pipe output and fix for some Airplay devices (release 57)
- persistent queues and support for Spotify saved tracks/albums (release 58)
- automatic playback of pipes + more resilient stream handling (release 59)
- mpd improvements and bug fixing (release 60)
- support for Apple TV4 device verification (release 61)
- playback improvements (release 62)
- web interface - thanks chme! (release 63)
- fix for Apple TV4, restart issue and Hyperfine (release 64)
- web interface and mpd improvements + misc bug fixes (release 65)
- fixes for iTunes XML scanner, ACL's and some internet streams (release 66)
- JSON output endpoints + fixes (release 67)
- player web interface (release 68)
- fix performance issue (release 69)
- fix for ATV4 and ipv6 (release 70)
- fix for Airplay 2 devices (release 71)
- ipv6 fall back to ipv4 and bug fixes (release 72/73)
- fix for pairing and other bugs (release 74)
- improvements to player web interface, e.g. artwork (release 75)
- fix for deadlock problem in previous release (release 76)
- web UI and JSON api improvements, db refactor (release 77)
- fix some segfaults in previous release (release 78)
- use Spotify's new api for artwork (release 79)
- web ui improvements (release 80)
- use native media quality + use Chromecast RTP (release 81)
- web ui improvements + bug fixes (release 82)
- mp3 metadata, Chromecast "sync" and web ui (release 83)
- web ui updates, mp3 streaming quality conf, Shairport artwork (release 84)
- fix for Apple Music (release 100)
- multiple alsa devices, more DACP commands (release 101)
- web ui improvements (release 102)
- nested playlists, DACP command fixes (release 103)
- minor fixes, web ui playlist folders (release 104)
- fix Homepod/ATV disconnects (release 105)
- fixes for input metadata handling (release 106)
- web ui improvements (release 107)
- misc volume fixes (release 108)
- Chromecast and web UI improvements (release 109)
- AirPlay 2 (release 110)
- ALAC compression for AirPlay 2 (release 111)
- Fix path traversal vulnerability (release 112)
Use at own risk
