sbp
Unable to compile 3.9.9
Sun Jul 14, 2013 7:02 am
Hi please help.
I have been able to compile 3.8.11, 3.8.12 and 3.8.13 linux-rpi before.
As suggested by gsh here http://www.raspberrypi.org/phpBB3/viewt ... &start=100 I have been using the config file "bcmrpi_defconfig".
But for the recent 3.9.9 I'm unable to make the crosscompile. My steps are:
make mrproper
copy the bcmrpi_defconfig file and rename it to .config
make ARCH=arm -j 3
And the compilation starts fine but at the end there are some errors and no image is produced (please have a look below)
So I would be very happy if someone would share a working .config file I could use.
Steen
 CC [M]  drivers/usb/serial/zio.o
  CC [M]  drivers/usb/serial/zte_ev.o
  LD [M]  drivers/usb/serial/usbserial.o
  LD      drivers/usb/built-in.o
  LD      drivers/built-in.o
  LINK    vmlinux
  LD      vmlinux.o
  MODPOST vmlinux.o
  GEN     .version
  CHK     include/generated/compile.h
  UPD     include/generated/compile.h
  CC      init/version.o
  LD      init/built-in.o
drivers/built-in.o: In function `vc_cma_init':
clkdev.c:(.text+0x2faa8): undefined reference to `vchiq_add_connected_callback'
drivers/built-in.o: In function `send_vc_msg':
clkdev.c:(.text+0x2fee0): undefined reference to `vchiq_use_service'
clkdev.c:(.text+0x2fef0): undefined reference to `vchiq_queue_message'
clkdev.c:(.text+0x2fefc): undefined reference to `vchiq_release_service'
drivers/built-in.o: In function `vc_cma_connected_init':
clkdev.c:(.text+0x2ff54): undefined reference to `vchiu_queue_init'
clkdev.c:(.text+0x2ff64): undefined reference to `vchiq_initialise'
clkdev.c:(.text+0x2ff74): undefined reference to `vchiq_connect'
clkdev.c:(.text+0x2ffa4): undefined reference to `vchiq_open_service'
clkdev.c:(.text+0x2ffb4): undefined reference to `vchiq_release_service'
clkdev.c:(.text+0x2fff8): undefined reference to `vchiq_shutdown'
clkdev.c:(.text+0x30000): undefined reference to `vchiu_queue_delete'
clkdev.c:(.text+0x30030): undefined reference to `vchiq_close_service'
drivers/built-in.o: In function `vc_cma_alloc_chunks.constprop.4':
clkdev.c:(.text+0x30168): undefined reference to `vchiq_use_service'
clkdev.c:(.text+0x30178): undefined reference to `vchiq_queue_message'
clkdev.c:(.text+0x30184): undefined reference to `vchiq_release_service'
drivers/built-in.o: In function `cma_worker_proc':
clkdev.c:(.text+0x302b8): undefined reference to `vchiu_queue_pop'
clkdev.c:(.text+0x30368): undefined reference to `vchiq_release_message'
drivers/built-in.o: In function `vc_cma_set_reserve':
clkdev.c:(.text+0x3068c): undefined reference to `vchiu_queue_push'
drivers/built-in.o: In function `cma_service_callback':
clkdev.c:(.text+0x30c14): undefined reference to `vchiu_queue_push'
drivers/built-in.o: In function `sdhci_set_clock':
clkdev.c:(.text+0xcd9ec): undefined reference to `enable_llm'
drivers/built-in.o: In function `sdhci_send_command':
clkdev.c:(.text+0xce7ec): undefined reference to `enable_llm'
drivers/built-in.o: In function `sdhci_spin_lock':
clkdev.c:(.text+0xcf2a4): undefined reference to `enable_llm'
drivers/built-in.o: In function `sdhci_spin_unlock':
clkdev.c:(.text+0xcf314): undefined reference to `enable_llm'
drivers/built-in.o: In function `sdhci_spin_lock_irqsave':
clkdev.c:(.text+0xcfb84): undefined reference to `enable_llm'
drivers/built-in.o:clkdev.c:(.text+0xcfc00): more undefined references to `enable_llm' follow
make: *** [vmlinux] Fejl 1
root@debian:/mrproper1/linux-rpi-3.9.y#
piCorePlayer webpage: https://sites.google.com/site/picoreplayer/home
MattF
Re: Unable to compile 3.9.9
Thu Jul 18, 2013 10:47 am
You need to disable CONFIG_BCM_VC_CMA
(This is also true at 3.10.X)
AFAIK it is no great loss
dom
Thu Jul 18, 2013 11:46 am
sbp wrote: copy the bcmrpi_defconfig file and rename it to .config
make ARCH=arm -j 3
You don't need to copy the config file. You should do:
make ARCH=arm bcmrpi_defconfig
make ARCH=arm -j 3
Return to “Advanced users”
