chalky_stewart
Dynamode USB Wifi Dongle issues
Sat Jul 13, 2013 9:33 pm
I recently bought a Dynamode WL-700N-RXS USB wifi dongle for the raspberry pi so that I could use it with xbmc.
Exact model is: http://www.amazon.co.uk/Dynamode-WL-700 ... rrypi+wifi
When I plug in the adaptor from lsusb I can see:
[email protected]:~$ lsusb
Bus 001 Device 004: ID 046d:c509 Logitech, Inc. Cordless Keyboard & Mouse
Bus 001 Device 005: ID 148f:7601 Ralink Technology, Corp.
It does not tell me the chipset but from amazon I can see it is: Ralink 5370 Chipset with lower power design
I then download firmware for it as follows:
sudo apt-get install firmware-ralink
Once this completes if I can run lsmod it returns:
Module Size Used by
ipv6 232892 31
xt_state 660 1
iptable_mangle 736 0
iptable_nat 2408 0
nf_nat 10526 1 iptable_nat
nf_conntrack_ipv4 8768 4 nf_nat,iptable_nat
nf_defrag_ipv4 716 1 nf_conntrack_ipv4
nf_conntrack 51300 4 nf_nat,xt_state,iptable_nat,nf_conntrack_ipv4
iptable_filter 616 1
ip_tables 10480 3 iptable_filter,iptable_mangle,iptable_nat
x_tables 10436 5 ip_tables,xt_state,iptable_filter,iptable_mangle,iptable_nat
spidev 3932 0
spi_bcm2708 4380 0
i2c_bcm2708 2872 0
i2c_core 20536 1 i2c_bcm2708
Which shows that the module/driver has not loaded.
Can anyone please advise?
Snap
Re: Dynamode USB Wifi Dongle issues
Wed Jul 17, 2013 10:38 pm
Even I have the same problem... Still don't know what to do.
llad
Mon Jul 22, 2013 7:51 pm
Hi
Yes same here.
After quite a lot of digging it looks like there is more than one version of WL-700N-RXS.
Mine has this P/N on the packaging V36WL-700N-RXS, it doesn't work OTB with wheezy.
Other version/versions have a red ring around the dongle and are based on a chipset that the kernel supports, according to some.
Mine reports.
After a lot of searching it looks like the chipset is ralink/mediatek MT7601 not yet supported by Linux kernel. Hence the 7601 Pid.
The mini CD that came with it has the source for a ralink linux driver but one of the folders is corrupt on the one I got. email to Dynamode support asking for download has yet to be answered.
So after more searching found this.
http://www.logicsupply.com/media/manual ... ronBBB.pdf
Which has some instructions and a link to a complete linux MT7601 chipset driver source code.
I have been able to compile on the Pi and it seems to work so far as device ra0.
Hope this helps.
Chandhar
Tue Jul 23, 2013 12:31 pm
Hi, I read the manual, and didn't get very far, is there any way you could please translate the instructions to work with the raspberry pi terminal (raspbian).
I'd really appreciate it :D
thanks in advance
pluggy
Tue Jul 23, 2013 2:15 pm
It it were an Ralink RT5370, it would just work on a later version of Raspdian (post September 2012). It doesn't need any patches for drivers.
lsub reports an RT5370 as
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
(or at least the 3 I own do)
Chandhar
Tue Jul 23, 2013 2:25 pm
When I brought my Dynamode dongle I THOUGHT i was going to receive the 5370, however at some point the manufacturer changed the chip-set so my dongle shows up as
unfortunately, this device doesn't appear to work natively :(
pluggy
Tue Jul 23, 2013 2:43 pm
Depending on your location and if you're not adverse to spending a little more dosh :
http://www.ebay.co.uk/itm/261226675344
This IS an RT5370 .
Could be an easy answer.
llad
Tue Jul 23, 2013 4:22 pm
Chandhar wrote:Hi, I read the manual, and didn't get very far, is there any way you could please translate the instructions to work with the raspberry pi terminal (raspbian).
thanks in advance
Hi Chandar.
Will see what I can do. There were quite a few steps involved.
Do you already have gcc compiler make etc installed and working?
Cheers
Chandhar
Tue Jul 23, 2013 4:41 pm
erm, no sorry, I haven't got that much experience with Linux, thank you though, once you have the guide drawn up I'll try and read between the lines and see what packages etc. I need.
Thanks again :)
llad
Tue Jul 23, 2013 5:54 pm
Chandhar wrote:erm, no sorry, I haven't got that much experience with Linux, thank you though, once you have the guide drawn up I'll try and read between the lines and see what packages etc. I need.
Thanks again :)
OK Here goes. I did say there was quite a few steps involved. I think the sequence is correct.
This howto is for models with MT7601 chipset.
Not units that report 5370, these should work with Raspbian wheezy out of the box.
First plug dongle into a USB port and boot your Pi.
Then
[email protected] ~ $ lsusb
If you have a device that looks like the above then you have the MT7601 version and this doesn't work with the standard drivers at time of posting.
This document gives a link to the ralink driver source for MT7601. It doesn't seem to be on the ralink website.
I am not sure how long this will be available.
This is how I built and installed it.
Install compiler and make tools.
Do this from a root terminal or add sudo infront of commands
[email protected]:/home/pi apt-get update
[email protected]:/home/pi apt-get upgrade
[email protected]:/home/pi apt-get install gcc make
Get the driver source.
From normal user terminal
[email protected] ~ $ mkdir src
[email protected] ~ $ cd src
[email protected] ~/src $ wget https://googledrive.com/host/0B_JlgOR4V ... LS.tar.bz2
[email protected] ~/src $ tar -xvjpf DPA_MT7601*
Get kernel sources - needed to build the driver
[email protected] ~/src $ mkdir kernel
[email protected] ~/src $ cd kernel
[email protected] ~/src/kernel $ wget https://github.com/raspberrypi/linux/ar ... 6.y.tar.gz
[email protected] ~/src/kernel $ tar xvfz rpi-3.6.y.tar.gz
Prepare the kernel/module sources so the driver can build with them.
[email protected] ~/src/kernel $ sudo ln -s /home/pi/src/kernel/linux-rpi-3.6.y /lib/modules/3.6.11+/build
[email protected] ~/src/kernel $ cd linux-rpi-3.6.y
[email protected] ~/src/kernel/linux-rpi-3.6.y $ make mrproper
[email protected] ~/src/kernel/linux-rpi-3.6.y $ gzip -dc /proc/config.gz > .config
[email protected] ~/src/kernel/linux-rpi-3.6.y $ make oldconfig
[email protected] ~/src/kernel/linux-rpi-3.6.y $ make prepare
[email protected] ~/src/kernel/linux-rpi-3.6.y $ make modules_prepare
[email protected] ~/src/kernel/linux-rpi-3.6.y $ wget https://github.com/raspberrypi/firmware ... le.symvers
Build the driver. You will see a lot of warnings just ignore them.
[email protected] ~ $ cd src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS/
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ make all
Install the driver. You should read the README_STA_usb in the MODULE folder for config info in the RT2870STA.dat.
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ mkdir -p /etc/Wireless/RT2870STA
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ sudo cp RT2870STA.dat /etc/Wireless/RT2870STA
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ sudo cp MODULE/os/linux/mt7601Usta.ko /lib/modules/3.6.11+/kernel/drivers/net/wireless/
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ sudo cp UTIL/os/linux/mtutil7601Usta.ko /lib/modules/3.6.11+/kernel/drivers/net/wireless/
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ sudo cp NETIF/os/linux/mtnet7601Usta.ko /lib/modules/3.6.11+/kernel/drivers/net/wireless/
[email protected] ~/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS $ depmod -a
Now reboot with the WL-700N-RXS inserted in a USB port.
If you do an ifconfig -a you should see ra0 as a network device.
Now you have the driver you need to config the wireless networking many people have posted info on how to do this.
Chandhar
Tue Jul 23, 2013 7:17 pm
hello again, thank you very much for all of your help and support, I have reached the last few instructions that require me to copy these files into the wireless drivers:
mt7601Usta.ko
mtutil7601Usta.ko
mtnet7601Usta.ko
however the files are not present in their respective directories, can you think of any reason why this might be.
PS I was very careful to follow each step as documented.
Thanks again for all of your help and support :)
llad
Tue Jul 23, 2013 7:53 pm
Chandhar wrote:hello again, thank you very much for all of your help and support, I have reached the last few instructions that require me to copy these files into the wireless drivers:
mt7601Usta.ko
mtutil7601Usta.ko
mtnet7601Usta.ko
That must mean that the driver build failed for some reason.
Run the above command again and see if you see any messages beginning with error before it stops.
Post them here and I will see if I can tell what the issue is.
Chandhar
Tue Jul 23, 2013 7:57 pm
this is the output I see upon running make all:
make -C UTIL/ osutil
make[1]: Entering directory `/home/pi/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS/UTIL'
cp -f os/linux/Makefile.6.util /home/pi/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS/UTIL/os/linux/Makefile
make -C /lib/modules/3.6.11+/build SUBDIRS=/home/pi/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS/UTIL/os/linux modules
make: Entering an unknown directory
make: *** /lib/modules/3.6.11+/build: No such file or directory. Stop.
make: Leaving an unknown directory
make[1]: *** [osutil] Error 2
make[1]: Leaving directory `/home/pi/src/DPA_MT7601U_LinuxSTA_3.0.0.3_20130717_LS/UTIL'
make: *** [all] Error 2
llad
Tue Jul 23, 2013 8:14 pm
Ha
I think that's an easy one.
This one is wrong.
[email protected] ~/src/kernel $ sudo ln -s /home/pi/src/kernel/linux-rpi-3.6.y /lib/modules/3.6.11+/build linux-rpi-3.6.y
Should have been.
Possibly didn't work as it was. Not sure how I got that typo in.
That creates a directory called "build" in /lib/modules/3.6.11+/ which isn't there at the moment hence the build failed.
Do an ls /lib/modules/3.6.11+/ after running it to make sure the build directory is there.
Then run make all command again.
Chandhar
Tue Jul 23, 2013 8:58 pm
the build finished this time and the three files have been copied over, after rebooting im still not seeing ra0 or any other signs that the wireless adapter is there other than lsusb to confirm it is plugged in.
Don't worry if you unable to help past this pointg (it could be anything from here)
thanks so much for all your help and guidance on the matter, I really appreciate it :)
llad
Tue Jul 23, 2013 9:08 pm
Try lsmod command.
The list it returns should include these 3 lines which means the kernel has seen the dongle and loaded the modules that you just compiled.
mtnet7601Usta 34716 1
mt7601Usta 1037966 1 mtnet7601Usta
mtutil7601Usta 70481 2 mt7601Usta,mtnet7601Usta
If they are there then it is probably working and you need to starting editing your /etc/network/interfaces.
Using ra0 instead of wlan0 that you will see in other posts.
Make sure you do "ifconfig -a" I'm pretty sure I give me an Ra0 entry before I did any network config.
But I may have put an entry in the interfaces file first.
Chandhar
Tue Jul 23, 2013 9:10 pm
lsmod returns this:
Module Size Used by
snd_bcm2835 16304 0
snd_pcm 77560 1 snd_bcm2835
snd_page_alloc 5145 1 snd_pcm
snd_seq 53329 0
snd_seq_device 6438 1 snd_seq
snd_timer 19998 2 snd_pcm,snd_seq
snd 58447 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
leds_gpio 2235 0
led_class 3562 1 leds_gpio
llad
Tue Jul 23, 2013 9:14 pm
They aren't loading.
did you do
sudo depmod -a
again after copying them into /lib/modules/... ?
that steps important otherwise the kernel wont know about the modules.
Chandhar
Tue Jul 23, 2013 9:16 pm
I did sudo depmod-a,
having run it again it still hasn't loaded the modules
llad
Tue Jul 23, 2013 9:20 pm
Can you post output of dmesg command.
May give some clues.
Chandhar
Tue Jul 23, 2013 9:22 pm
sure :D
[email protected] ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #474 PREEMPT Thu Jun 13 17:14:42 BST 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 1b000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c053b854, node_mem_map c05e5000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 113792 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708.boardrev=0xd bcm2708.serial=0x152c3d18 smsc95xx.macaddr=B8:27:EB:2C:3D:18 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 448MB = 448MB total
[ 0.000000] Memory: 432264k/432264k available, 26488k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04e647c (4986 kB)
[ 0.000000] .init : 0xc04e7000 - 0xc0507f24 ( 132 kB)
[ 0.000000] .data : 0xc0508000 - 0xc053c080 ( 209 kB)
[ 0.000000] .bss : 0xc053c0a4 - 0xc05e4758 ( 674 kB)
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001030] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060125] pid_max: default: 32768 minimum: 301
[ 0.060460] Mount-cache hash table entries: 512
[ 0.061218] Initializing cgroup subsys cpuacct
[ 0.061272] Initializing cgroup subsys devices
[ 0.061306] Initializing cgroup subsys freezer
[ 0.061335] Initializing cgroup subsys blkio
[ 0.061426] CPU: Testing write buffer coherency: ok
[ 0.061763] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.061905] Setting up static identity map for 0x39d698 - 0x39d6f4
[ 0.063400] devtmpfs: initialized
[ 0.074051] NET: Registered protocol family 16
[ 0.080538] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081640] bcm2708.uart_clock = 0
[ 0.083029] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.083084] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.083120] mailbox: Broadcom VideoCore Mailbox driver
[ 0.083215] bcm2708_vcio: mailbox at f200b880
[ 0.083316] bcm_power: Broadcom power driver
[ 0.083355] bcm_power_open() -> 0
[ 0.083380] bcm_power_request(0, 8)
[ 0.584070] bcm_mailbox_read -> 00000080, 0
[ 0.584113] bcm_power_request -> 0
[ 0.584140] Serial: AMBA PL011 UART driver
[ 0.584283] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.908117] console [ttyAMA0] enabled
[ 0.931755] bio: create slab <bio-0> at 0
[ 0.936637] SCSI subsystem initialized
[ 0.940733] usbcore: registered new interface driver usbfs
[ 0.946318] usbcore: registered new interface driver hub
[ 0.951916] usbcore: registered new device driver usb
[ 0.958274] Switching to clocksource stc
[ 0.962514] FS-Cache: Loaded
[ 0.965647] CacheFiles: Loaded
[ 0.980425] NET: Registered protocol family 2
[ 0.985703] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.993445] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.000238] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.006846] TCP: reno registered
[ 1.010098] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.015996] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.022587] NET: Registered protocol family 1
[ 1.027455] RPC: Registered named UNIX socket transport module.
[ 1.033499] RPC: Registered udp transport module.
[ 1.038221] RPC: Registered tcp transport module.
[ 1.042968] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.050080] bcm2708_dma: DMA manager at f2007000
[ 1.054869] bcm2708_gpio: bcm2708_gpio_probe c0515d98
[ 1.060338] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.069497] audit: initializing netlink socket (disabled)
[ 1.075093] type=2000 audit(0.930:1): initialized
[ 1.197280] VFS: Disk quotas dquot_6.5.2
[ 1.201317] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.208382] FS-Cache: Netfs 'nfs' registered for caching
[ 1.214134] NFS: Registering the id_resolver key type
[ 1.219327] Key type id_resolver registered
[ 1.223624] Key type id_legacy registered
[ 1.227988] msgmni has been set to 876
[ 1.233524] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.241233] io scheduler noop registered
[ 1.245280] io scheduler deadline registered (default)
[ 1.250464] io scheduler cfq registered
[ 1.276427] Console: switching to colour frame buffer device 90x30
[ 1.288854] kgdb: Registered I/O driver kgdboc.
[ 1.296267] vc-cma: Videocore CMA driver
[ 1.302405] vc-cma: vc_cma_base = 0x00000000
[ 1.309213] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.316757] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.333315] brd: module loaded
[ 1.343460] loop: module loaded
[ 1.349060] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
[ 1.358828] Loading iSCSI transport class v2.0-870.
[ 1.366910] usbcore: registered new interface driver smsc95xx
[ 1.375056] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.588054] Core Release: 2.80a
[ 1.593331] Setting default values for core params
[ 1.600155] Finished setting default values for core params
[ 1.812822] Using Buffer DMA mode
[ 1.818133] Periodic Transfer Interrupt Enhancement - disabled
[ 1.826002] Multiprocessor Interrupt Enhancement - disabled
[ 1.833656] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.840067] Dedicated Tx FIFOs mode
[ 1.846532] dwc_otg: Microframe scheduler enabled
[ 1.846935] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.854038] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.863445] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.871025] Init: Port Power? op_state=1
[ 1.876992] Init: Power Port (0)
[ 1.882265] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.891130] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.900437] usb usb1: Product: DWC OTG Controller
[ 1.907215] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.915086] usb usb1: SerialNumber: bcm2708_usb
[ 1.922583] hub 1-0:1.0: USB hub found
[ 1.928511] hub 1-0:1.0: 1 port detected
[ 1.934912] dwc_otg: FIQ enabled
[ 1.934931] dwc_otg: NAK holdoff enabled
[ 1.934951] Module dwc_common_port init
[ 1.935169] Initializing USB Mass Storage driver...
[ 1.942481] usbcore: registered new interface driver usb-storage
[ 1.950591] USB Mass Storage support registered.
[ 1.957457] usbcore: registered new interface driver libusual
[ 1.965628] mousedev: PS/2 mouse device common for all mice
[ 1.974100] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.982082] bcm2835-cpufreq: switching to governor powersave
[ 1.989868] bcm2835-cpufreq: switching to governor powersave
[ 1.997567] cpuidle: using governor ladder
[ 2.003674] cpuidle: using governor menu
[ 2.009574] sdhci: Secure Digital Host Controller Interface driver
[ 2.017736] sdhci: Copyright(c) Pierre Ossman
[ 2.024158] sdhci: Enable low-latency mode
[ 2.072562] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.082633] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.092733] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.106232] usbcore: registered new interface driver usbhid
[ 2.114010] usbhid: USB HID core driver
[ 2.124654] TCP: cubic registered
[ 2.132127] Initializing XFRM netlink socket
[ 2.140609] Indeed it is in host mode hprt0 = 00021501
[ 2.147915] NET: Registered protocol family 17
[ 2.162564] Key type dns_resolver registered
[ 2.182997] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.195836] registered taskstats version 1
[ 2.224746] mmc0: read SD Status register (SSR) after 2 attempts
[ 2.233614] Waiting for root device /dev/mmcblk0p2...
[ 2.257304] mmc0: new high speed SDHC card at address e624
[ 2.272994] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 2.281551] mmcblk0: p1 p2
[ 2.374070] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.386761] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.395193] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.404526] Indeed it is in host mode hprt0 = 00001101
[ 2.426894] devtmpfs: mounted
[ 2.442738] Freeing init memory: 128K
[ 2.622691] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.632492] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.642902] hub 1-1:1.0: USB hub found
[ 2.649591] hub 1-1:1.0: 3 ports detected
[ 2.932585] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.053097] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.062525] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.076235] smsc95xx v1.0.4
[ 3.137430] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2c:3d:18
[ 3.232622] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.730333] usb 1-1.2: New USB device found, idVendor=148f, idProduct=7601
[ 3.739977] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.475075] udevd[154]: starting version 175
[ 5.628031] Registered led device: led0
[ 5.723293] mtutil7601Usta: disagrees about version of symbol module_layout
[ 9.335620] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.911041] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.765833] mtutil7601Usta: disagrees about version of symbol module_layout
[ 19.527613] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 20.954695] bcm2835-cpufreq: switching to governor ondemand
[ 20.954724] bcm2835-cpufreq: switching to governor ondemand
[ 28.244604] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:507900k SS
really hope this makes more sense to you than me, I'll try and read through it aswell and see what I can make of it :)
llad
Tue Jul 23, 2013 9:30 pm
This line
Tells us it recognised it needed to load the driver module.
But it looks like its something to do with kernel/module version.
Have you ever done an rpi-update. If not the kernel source downloaded may be newer than the kernel you are running.
Which is possibly causing the problem.
Chandhar
Tue Jul 23, 2013 9:33 pm
I haven't, i am doing so now,
do you think, i'll need to build and compile the kernel again?
also, if you don't mind my asking how much experience do you have with Linux, it blows my mind how you are so knowledgeable, and how quick you were to see a fault :D
llad
Tue Jul 23, 2013 9:50 pm
Hopefully I think after doing an rpi-update you should just be able to copy the mt*.ko files over to /lib/modules/... again.
Because the source you have should match the latest build.
The rpi-update will replace the old /lib/modules.
Don't forget depmod -a
If not you may have to start again from
[email protected] ~/src/kernel/linux-rpi-3.6.y $ make mrproper.
Also a make clean will be needed before make all in the driver source directory.
Don't mind you asking. I've been using Unix/Linux on and off for 20+ years.
Chandhar
Wed Jul 24, 2013 6:06 pm
Hi, just keeping you updated, I haven't had a chance to play with this, and probably won't till tommorrow,
thanks again for all your help :)
