Bamse5b
Raspberry pi does not boot correctly
Sat Jul 13, 2013 3:54 pm
I just downloaded the newest image burned it to an sd card that Ive formatted earlier. But when I boot everything runs fine until it starts showing debug info. I type "login" to try to login but when I write pi/raspberry it says incorrect login! Does anyone know any solutions? BTW this is the newest wheezy image.
ukscone
Re: Raspberry pi does not boot correctly
Sat Jul 13, 2013 4:06 pm
you don't type login to login. the
login:
prompt is when/where you type the id & password.
what you were doing was trying to login with a username of login & a password of pi
Bamse5b
Sat Jul 13, 2013 9:22 pm
It never reaches there! it outputted alot of debug code and wont reach the config point. Ive tried downloading a new image to see if it worked, but still the same!
joan
Sat Jul 13, 2013 9:31 pm
It sounds like it has failed to complete boot.
Could you type the last few lines on the screen or upload a photo of the screen?
Bamse5b
Sat Jul 13, 2013 9:41 pm
joan wrote:It sounds like it has failed to complete boot.
Need some sleep first
Bamse5b
Sun Jul 14, 2013 2:23 pm
Image Sorry for the bad quality
rpdom
Sun Jul 14, 2013 3:13 pm
You're running in "safe mode".
It usually happens if something is connected to pins 5 and 6 of P1, although a few people seem to have found that their Pi boots in that mode anyway. Maybe it needs more investigation.
You can force a normal boot by adding "avoid_safe_mode=1" to the config.txt file.
Bamse5b
Sun Jul 14, 2013 5:23 pm
rpdom wrote:You're running in "safe mode".
I will try
