gm1wkr
xinetd - Invalid Package
Fri Jul 12, 2013 6:03 pm
sudo yum install xinetd
results in
2:xinetd-2.3.15-4.fc18.armv6hl: Downloaded package 2:xinetd-2.3.15-4.fc18.armv6hl, from pidora, but it was invalid.
I am trying to install "node" for AX.25, xinetd is a dependency. Any help appreciated.
The whole transaction is copied below,
[gm1wkr@raspi sysconfig]$ sudo yum install xinetd
Loaded plugins: langpacks, presto, refresh-packagekit
Resolving Dependencies
--> Running transaction check
---> Package xinetd.armv6hl 2:2.3.15-4.fc18 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
 Package        Arch            Version                    Repository      Size
Installing:
 xinetd         armv6hl         2:2.3.15-4.fc18            pidora         113 k
Transaction Summary
Install  1 Package
Total download size: 113 k
Installed size: 235 k
Is this ok [y/N]: y
Downloading Packages:
xinetd-2.3.15-4.fc18.armv6hl.r FAILED
http://pidora.proximity.on.ca/pidora/releases/18/packages/armv6hl/os/Packages/x/xinetd-2.3.15-4.fc18.armv6hl.rpm: [Errno 14] HTTP Error 404 - Not Found : http://pidora.proximity.on.ca/pidora/releases/18/packages/armv6hl/os/Packages/x/xinetd-2.3.15-4.fc18.armv6hl.rpm
Trying other mirror.
http://downloads.raspberrypi.org/pidora/releases/18/packages/armv6hl/os/Packages/x/xinetd-2.3.15-4.fc18.armv6hl.rpm: [Errno 14] HTTP Error 404 - Not Found : http://downloads.raspberrypi.org/pidora/releases/18/packages/armv6hl/os/Packages/x/xinetd-2.3.15-4.fc18.armv6hl.rpm
Error Downloading Packages:
  2:xinetd-2.3.15-4.fc18.armv6hl: [Errno 256] No more mirrors to try.
Cheers in advance,
Mike
gm1wkr
Re: xinetd - Invalid Package
Sat Jul 13, 2013 12:57 pm
It looks like pidora.ca had some problems yesterday, the xinetd package is there this morning and valid.
Cheers,
Mike
Return to “Pidora / Fedora”
