I have been having trouble getting the codec license keys to work. This is my second PI model B and the previous unit worked as expected.
The problem I am experiencing is that when ever I run the command vcgencmd codec_enabled MPG2 I get the following error.
VCHI initialization failed
Having spent some time researching this error, my understanding is that there is a problem with old firmware on some of the Raspberry PI. I just received it, however I suppose it could be old stock. I tried to install the program RPI-UPDATE to do a firmware upgrade using apt-get install rpi-update as it is listed on Hexxeh's blog and apt-get reports that it was unable to find the package. I also tried wget with no luck.... Is there another way to get it and is the firmware indeed the issue?
Thanks,
