PsycoMEn
Hello_video with video position parameters
Tue Jul 09, 2013 3:05 pm
Hi there,
i'm trying to change hello_video so it supports as input argument the windows position, like omxplayer ( --win "x1 y1 x2 y2" Set position of video window )
I tried to read the code from omxplayer and include it on hello_video without success :(
can any one help me!!!
Thanks.
PsycoMEn
Re: Hello_video with video position parameters
Tue Jul 09, 2013 9:02 pm
I'm still trying without any luck
The code that i think does the trick in omxplayer is:
#include <IL/OMX_Video.h>
#include <IL/OMX_Broadcom.h>
   OMX_CONFIG_DISPLAYREGIONTYPE configDisplay;
   memset(&configDisplay, 0, sizeof(OMX_CONFIG_DISPLAYREGIONTYPE));
   configDisplay.nVersion.nVersion = OMX_VERSION;
   configDisplay.nPortIndex = 130;
   configDisplay.set = OMX_DISPLAY_SET_DEST_RECT;
   configDisplay.dest_rect.x_offset  = 100;
   configDisplay.dest_rect.y_offset  = 100;
   configDisplay.dest_rect.width     = 640;
   configDisplay.dest_rect.height    = 480;
   OMX_SetParameter(ILC_GET_HANDLE(video_decode), OMX_IndexConfigDisplayRegion, &configDisplay);
but i tried to add it to line 117 after format.eCompressionFormat = OMX_VIDEO_CodingAVC; but the image still goes fullscreen.
help!!!
Wed Jul 10, 2013 11:27 am
Does the set parameter call return any sort of error? That might help track down any issues.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
PsycoMEn
Wed Jul 10, 2013 1:22 pm
I get -2147479526 as output to the command.
Don't know what mean...
Am I missing out any parameter to set?? I thinks that's the right function to setup a specific area for the output.
dom
Wed Jul 10, 2013 1:47 pm
PsycoMEn wrote: I get -2147479526 as output to the command.
-2147479526 = 0x8000101A
Which OMX_Core.h shows is:
  /** The parameter or config indicated by the given index is not supported. */
  OMX_ErrorUnsupportedIndex = (OMX_S32) 0x8000101A,
and the reason:
OMX_IndexConfigDisplayRegion is a rendering option. It should go to video_render component, not video_decode.
Wed Jul 10, 2013 2:39 pm
I was just about to say that... ;)
PsycoMEn
Wed Jul 10, 2013 7:22 pm
Sucess :D
After many makes and runs here's my code:
Put it after line 115
   ilclient_change_component_state(video_render, OMX_StateIdle);
   configDisplay.nSize = sizeof(OMX_CONFIG_DISPLAYREGIONTYPE);
   configDisplay.nPortIndex = 90;
   configDisplay.fullscreen = OMX_FALSE;
   configDisplay.noaspect   = OMX_TRUE;
   configDisplay.set = (OMX_DISPLAYSETTYPE)(OMX_DISPLAY_SET_DEST_RECT|OMX_DISPLAY_SET_SRC_RECT|OMX_DISPLAY_SET_FULLSCREEN|OMX_DISPLAY_SET_NOASPECT);
   configDisplay.dest_rect.x_offset  = 50;
   configDisplay.dest_rect.y_offset  = 50;
   configDisplay.dest_rect.width     = 1280;
   configDisplay.dest_rect.height    = 720;
   configDisplay.src_rect.x_offset   = 0;
   configDisplay.src_rect.y_offset   = 0;
   configDisplay.src_rect.width      = 1280;
   configDisplay.src_rect.height     = 720;
   int stat = 0;
   stat =  OMX_SetParameter(ILC_GET_HANDLE(video_render), OMX_IndexConfigDisplayRegion, &configDisplay);
   printf ("stat= %#x\n", stat);
Now o get 0 in stat :P ,needs a little polish but it does the job.
Thank you very much for the help. The sugestion were real eyes opener.
Thanks to both.
