PsycoMEn
Hello_video with video position parameters
Tue Jul 09, 2013 3:05 pm
Hi there,
i'm trying to change hello_video so it supports as input argument the windows position, like omxplayer ( --win "x1 y1 x2 y2" Set position of video window )
I tried to read the code from omxplayer and include it on hello_video without success :(
can any one help me!!!
Thanks.
PsycoMEn
Re: Hello_video with video position parameters
Tue Jul 09, 2013 9:02 pm
I'm still trying without any luck
The code that i think does the trick in omxplayer is:
#include <IL/OMX_Video.h>
#include <IL/OMX_Broadcom.h>
   OMX_CONFIG_DISPLAYREGIONTYPE configDisplay;
   memset(&configDisplay, 0, sizeof(OMX_CONFIG_DISPLAYREGIONTYPE));
   configDisplay.nVersion.nVersion = OMX_VERSION;
   configDisplay.nPortIndex = 130;
   configDisplay.set = OMX_DISPLAY_SET_DEST_RECT;
   configDisplay.dest_rect.x_offset  = 100;
   configDisplay.dest_rect.y_offset  = 100;
   configDisplay.dest_rect.width     = 640;
   configDisplay.dest_rect.height    = 480;
   OMX_SetParameter(ILC_GET_HANDLE(video_decode), OMX_IndexConfigDisplayRegion, &configDisplay);
but i tried to add it to line 117 after format.eCompressionFormat = OMX_VIDEO_CodingAVC; but the image still goes fullscreen.
help!!!
Wed Jul 10, 2013 11:27 am
Does the set parameter call return any sort of error? That might help track down any issues.
PsycoMEn
Wed Jul 10, 2013 1:22 pm
I get -2147479526 as output to the command.
Don't know what mean...
Am I missing out any parameter to set?? I thinks that's the right function to setup a specific area for the output.
dom
Wed Jul 10, 2013 1:47 pm
PsycoMEn wrote: I get -2147479526 as output to the command.
-2147479526 = 0x8000101A
Which OMX_Core.h shows is:
  /** The parameter or config indicated by the given index is not supported. */
  OMX_ErrorUnsupportedIndex = (OMX_S32) 0x8000101A,
and the reason:
OMX_IndexConfigDisplayRegion is a rendering option. It should go to video_render component, not video_decode.
Wed Jul 10, 2013 2:39 pm
I was just about to say that... ;)
PsycoMEn
Wed Jul 10, 2013 7:22 pm
Sucess :D
After many makes and runs here's my code:
Put it after line 115
   ilclient_change_component_state(video_render, OMX_StateIdle);
   configDisplay.nSize = sizeof(OMX_CONFIG_DISPLAYREGIONTYPE);
   configDisplay.nPortIndex = 90;
   configDisplay.fullscreen = OMX_FALSE;
   configDisplay.noaspect   = OMX_TRUE;
   configDisplay.set = (OMX_DISPLAYSETTYPE)(OMX_DISPLAY_SET_DEST_RECT|OMX_DISPLAY_SET_SRC_RECT|OMX_DISPLAY_SET_FULLSCREEN|OMX_DISPLAY_SET_NOASPECT);
   configDisplay.dest_rect.x_offset  = 50;
   configDisplay.dest_rect.y_offset  = 50;
   configDisplay.dest_rect.width     = 1280;
   configDisplay.dest_rect.height    = 720;
   configDisplay.src_rect.x_offset   = 0;
   configDisplay.src_rect.y_offset   = 0;
   configDisplay.src_rect.width      = 1280;
   configDisplay.src_rect.height     = 720;
   int stat = 0;
   stat =  OMX_SetParameter(ILC_GET_HANDLE(video_render), OMX_IndexConfigDisplayRegion, &configDisplay);
   printf ("stat= %#x\n", stat);
Now o get 0 in stat :P ,needs a little polish but it does the job.
Thank you very much for the help. The sugestion were real eyes opener.
Thanks to both.
