JakeyDad4
Re: Two WiFi Adapters
Thu May 04, 2017 9:20 pm
MrEngman
I have a set up in mind that I wanted to make. I have in mind to install a pi in my car using the video in on my stereo and running OSMC on the pi. One problem I'm having is controlling the pi. In my home I have a second Pi for a media center and I control it with the Kore Remote app, I was curious if you knew whether your configuration would allow one wifi adapter to transmit a network to connect to the Kore app, while the other would allow connection to a wifi internet whenever available? Your thoughts?
Thank you so much!
junaidsyed
Sun Apr 15, 2018 12:22 am
create a new file in directory /etc/wpa_supplicant/. The new file should be named with interface name i.e
wpa_supplicant-wlan1.conf
- file /etc/wpa_supplicant/wpa_supplicant-wlan0.conf for interface wlan0
- file /etc/wpa_supplicant/wpa_supplicant-wlan1.conf for interface wlan1
- content of wpa_supplicant-wlan0.conf file
update_config=1
country=US
network={
ssid="ssid0"
psk="pass0"
- content of wpa_supplicant-wlan1.conf file
update_config=1
country=US
network={
ssid="ssid1"
psk="pass1"
reboot PI and you should have SSID attached to an interface.
