Wed Apr 18, 2012 6:15 pm
I can't comment on the RasPi specifically, but it seems a bit naughty to produce such a device, given that the USB spec is 5.25 V maximum. I assume your device was built just for battery charging, and/or they count on a certain amount of drop through the cable.
5V 1A should be more than enough for the RasPi by itself, it has a 700 mA maximum rating. Any power-hungry USB devices like hard drives, should connect through a separately powered USB hub.
