Montala said:
rmwebs said:
I'm using one of these and it works fine:
http://www.ebuyer.com/135103-x.....sb-kb-1000
One thing I will say is watch the power. If you find your wireless (or even wired) keyboard/mouse arent working or work intermittently, unplug everything else that uses USB.
Personally I'd recommend running all USB stuff through a GOOD, EXPENSIVE, BRANDED hub, Not a cheap, crummy eBuyer or eBay hub as these are NOT as powerful as they should be, and wont work properly as they dont provide enough power in most cases.
That one looks interesting... does the touch-pad work OK with the Raspberry Pi also?
Surprisingly, yes. I have to say that I wasnt expecting it to, but it works fine and is pretty well thought out. The left/right click buttons are on the left of the keyboard so you can keep your hands either side. I thought it would be a bit odd but its actually really nice to use. You can also 'tap' the touchpad to click - that seems to work fine on the Pi too.
I can only assume that the USB dongle effectively converts the keyboards input into a virtual native keyboard/mouse.
