RaTTuS
Contact: Twitter YouTube
Arm Boards with 1000Ethernet
Mon Jul 01, 2013 11:37 am
I'm on the look out for an arm board that I can run linux with 1Gb/s ethernet
what are my options
please no flames it's for a project that a colleague is investigating an he needs a few options
Covfefe
OtherCrashOverride
Re: Arm Boards with 1000Ethernet
Mon Jul 01, 2013 11:50 am
The i.MX6 boards are looking very attractive. If you need gigabit ethernet, then u probably also need the computational power to drive it. So take a look at the Wandboard Quad:
http://www.wandboard.org/index.php/details
RaTTuS
Wed Jul 24, 2013 2:28 pm
http://shop.adapteva.com/collections/pa ... allella-16
I've just ordered one .....
and got my mate to do the same....
not quite what he was looking for but ........ ;)
Covfefe
plugwash
Wed Jul 31, 2013 11:02 pm
OtherCrashOverride wrote:The i.MX6 boards are looking very attractive. If you need gigabit ethernet, then u probably also need the computational power to drive it. So take a look at the Wandboard Quad:
Be aware that the IMX6 can apparently only achive about half a gigabit per second of throughput due to internal bus limitations.
OtherCrashOverride
Thu Aug 01, 2013 2:47 am
All ARM SoC's have their fair share of "dirty little secrets". The Gbit Ethernet issue is documented in the chip errata:
http://cache.freescale.com/files/32bit/ ... X6DQCE.pdf
ERR004512 ENET: 1 Gb Ethernet MAC (ENET) system limitation
The theoretical maximum performance of 1 Gbps
ENET is limited to 470 Mbps (total for Tx and
Rx). The actual measured performance in optimized environment is up to 400 Mbps.
LordDamien
Sun Oct 27, 2013 2:48 am
I was looking too for a similar board, and there is plenty of options. However the main issue is storage, as everything goes through the usb 2.0 hub, ensuring that file transmission will always be at usb 2.0 speed.
The closest thing I've found is this: http://www.plugcomputer.org/development-kits/dreamplug/
But it is very pricey and after seeing the performance of its cousin guruplug server, I would stay the hell away from it:
http://1wt.eu/articles/guruplug-slow-heater/
Me does not like intel, yet they have a heavy competitor with this one:
http://www.mini-box.com/Intel-D2500HN-M ... otherboard
Raspberry people (or Santa),
Please make an esata independent from the usb 2.0 (or usb 3.0) and 1G ethernet server below 100$.
Thank you,
W. H. Heydt
Sun Oct 27, 2013 5:21 am
LordDamien wrote: Please make an esata independent from the usb 2.0 (or usb 3.0) and 1G ethernet server below 100$.
While I agree that that would be nice, I'm not holding my breath. To begin with, it would take an entirely different SoC. (So far as I know, the BCM2835 doesn't have any sort of SATA interface built into it.)
You might want to look at the CubieTruck (specs: https://www.miniand.com/products/Cubiet ... ev%20Board). It appears to have what you're asking for at the price you want.
Sun Oct 27, 2013 9:26 am
LordDamien wrote:I was looking too for a similar board, and there is plenty of options. However the main issue is storage, as everything goes through the usb 2.0 hub, ensuring that file transmission will always be at usb 2.0 speed.
Thank you,
Sorry, not going to happen. There are other devices that fit your specifications, or you could design one yourself.
RaTTuS
Mon Oct 28, 2013 9:14 am
http://www.ebay.co.uk/itm/TonidoPlug2-C ... 0939143727
I went with one of those for my 1Gb NIC need
Covfefe
Return to “Off topic discussion”
