jobesystems
Relays, GPIOs, and PiFace
Mon Jul 01, 2013 4:29 am
Hey all,
So I'm testing some code and I'm reading GPIOs just fine, but when I try to write to the relays they aren't working.
wiringpi2.digitalWrite(216,1) is what I'm using to set Relay 1 to closed. Is that not the correct format?
wiringpi2.digitalWrite(216,0) is what I'm using to set Realy 1 to open.
Also, does anyone have any guidance on using wiringpi2 to monitor GPIOs so that I can automatically trigger things? I was going to use RPIO and interrupts, but RPIO doesn't seem to support PiFace. I'm going to have another system connected via IP socket and I don't want it to have to keep sending strings periodically to "poll" the GPIOs.
Thanks.
Mike
PiGraham
Re: Relays, GPIOs, and PiFace
Mon Jul 01, 2013 4:58 am
Have you read this?
https://projects.drogon.net/raspberry-pi/wiringpiface/
Piface outputs are different to Pi outputs. Make sure you initialise correctly.
Return to “Python”
