pillumi
yum install is failed
Sat Jun 29, 2013 11:37 am
Hi all,
I bought Raspberry pi and installed Pidora 18(Raspberry Pi Fedora Remix).
I tried to install ldap-client by yum command, but yum command is failed.
Will you please tell us the reason and the solution?
Error log is below:
[root@raspi etc]# yum install openldap-clients
Loaded plugins: langpacks, presto, refresh-packagekit
pidora-updates | 3.8 kB 00:00
http://pidora.proximity.on.ca/pidora/re ... -18.xml.gz: [Errno 14] HTTP Error 404 - Not Found : http://pidora.proximity.on.ca/pidora/re ... -18.xml.gz
Trying other mirror.
http://downloads.raspberrypi.org/pidora ... -18.xml.gz: [Errno 14] HTTP Error 404 - Not Found : http://downloads.raspberrypi.org/pidora ... -18.xml.gz
http://pidora.proximity.on.ca/pidora/rp ... -18.xml.gz: [Errno 14] HTTP Error 404 - Not Found : http://pidora.proximity.on.ca/pidora/rp ... -18.xml.gz
pidora/primary_db FAILED
(1/2): pidora/primary_db 0% [ ] 0.0 B/s | 0 B --:-- ETA http://pidora.proximity.on.ca/pidora/re ... sqlite.bz2: [Errno 14] HTTP Error 404 - Not Found : http://pidora.proximity.on.ca/pidora/re ... sqlite.bz2
pidora-rpfr-updates/primary_db FAILED
(1/2): pidora-rpfr-updates 0% [ ] 0.0 B/s | 0 B --:-- ETA http://pidora.proximity.on.ca/pidora/rp ... sqlite.bz2: [Errno 14] HTTP Error 404 - Not Found : http://pidora.proximity.on.ca/pidora/rp ... sqlite.bz2
(1/2): pidora/primary_db 0% [ ] 0.0 B/s | 0 B --:-- ETA http://downloads.raspberrypi.org/pidora ... sqlite.bz2: [Errno 14] HTTP Error 404 - Not Found : http://downloads.raspberrypi.org/pidora ... sqlite.bz2
(1/2): pidora-rpfr-updates 0% [ ] 0.0 B/s | 0 B --:-- ETA http://downloads.raspberrypi.org/pidora ... sqlite.bz2: [Errno 14] HTTP Error 404 - Not Found : http://downloads.raspberrypi.org/pidora ... sqlite.bz2
Error: failure: repodata/5c8d0f92034d0dc62b10a563043e1adf2f501b7487192979953aaf32aee87a8c-primary.sqlite.bz2 from pidora: [Errno 256] No more mirrors to try.
[root@raspi etc]#
magistros
Re: yum install is failed
Tue Jul 02, 2013 8:49 am
Hi!
I had the same error and I did
yum clean all
and then it worked perfectly. Try it and let me know what happened....
pillumi
Fri Jul 05, 2013 2:30 pm
magistros,
I could did it well according to your reply.
Thank you!
Return to “Pidora / Fedora”
