ebaydan777
Need help with a Nightclub Project! Output to Multiple Tv's!
Fri Jun 28, 2013 10:08 pm
Hey everyone, I VERY MUCH appreciate any help or ideas I can do to make this happen.
I currently have about 5 TV's in various locations behind my bar, behind the DJ booth, and In the DJ booth.
I am currently using a simple old school method. A computer running Resolume VJ Software, tied to a Roland V-4 VJ Mixer.
Link Here: http://www.sweetwater.com/store/detail/ ... Qgod0AoAIQ
The problem is, I am limited to only Composite input while each TV is a plasma HDMI 50", so it doesn't look great, not sure what the previous owner was thinking, or if the technology was available then.
Either way, I wanted to instead spend about $100 on each Raspberry Pi (including the Pi, casing, power, etc) And I believe each TV may even have a HDD enabled USB in the back, enough to power the Pi.
I'd like to create some sort of system in which I can still use that computer back there, have all the Pi's connect to a local network (router) so they can communicate (also wirelessly). I'm basically trying to get all 5 of these screen's to have the exact same thing on the screen. Whether it's just running files off a media center, or even better: I would prefer if I could get Resolume to run the programming I need for my video jockey's, and to run that output onto all the screens.
Now how in the world can I do this, im past novice with these things but definitely no expert. And again, I really appreciate the help. I want to build something new in San Diego and I think if I can finally get things looking the way they should in my business, it would certainly help us a lot!
Thank you!
Edit: I've included some photos so you can see what I mean. The first is the dance floor and DJ booth at the end with 2 TV's. the VJ computer and equipment sit behind that area. The others are picture of the bar which is located where I am taking the first DJ booth photo from, so right behind me on the opposite side of the room.
Album: http://imgur.com/a/o8pIs
PiGraham
Re: Need help with a Nightclub Project! Output to Multiple T
Fri Jun 28, 2013 10:19 pm
Somebody posting here has made some software that might suit. Not sure of details but I think it was called Screenly.
Someone else posted about a similar system with reference to museum information, "Pi Presents", I think.
Maybe try searching the forum for "presentation", "multicast", "RTSP".
