I've run few days ago:
sudo dist-upgrade Code: Select all
Linux raspberrypi 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/LinuxDetails:
pi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless AdapterCode: Select all
wlan0 Link encap:Ethernet HWaddr 00:0f:54:0d:b9:bb
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)Code: Select all
pi@raspberrypi ~ $ iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:onCode: Select all
pi@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
address 192.168.0.49
netmask 255.255.255.0
gateway 192.168.0.1
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcpCode: Select all
pi@raspberrypi ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
[b]ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1[/b]
network={
ssid="SKYA767C"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="!!1234RFV"
2nd - I've try to manage my wlan0 myself last week and I had a connectivity for a moment, now I've lost it again.
Can you please advise what's wrong - what need to be fixed?
