antiloquax said:
Hi, I'm sorry you've had some problems with RacyPy.
You need some software that will burn an .iso image.
I think you can do it in Nero and so on, but I like this little program:
http://www.dvddecrypter.org.uk/
Once you have installed it, you just need to right click it and choose "Burn using DVD Decrypter". Then click on the picture at the bottom of the window and you'll be away!
Once you've booted up, you can start programming in Python straight away. There are some tutorials in "my-documents" they are in an archive - just click on it and the archive program will open it for you.
Thanks again for downloading this!
mark
This is not in the complete beginners section for nothing!!!!...ok downloaded the little dvddecrypter prog, all aok set it up for 'write an ISO'.., got my CD drive as the'destination'. when it comes to find a file to write to the CD, can't find one... anything I try to select to put in the 'source' box is a non-starter. I don't have an .iso file in the load of files that came from the Racy-Pi download, there are 14 files resulting from unzipping the Racy-Py download, 3 are called 'boot', some 'outlooks'. CFG, BIN, SFS but nothing that looks like a .ISO file. Where am I going wrong?? Help!
