I am planning to install solar heating for my pool but want to build my own control center for it. Normally those systems costs a lot and only thing they do is measuring temperature of water and rooftop and then open or close a 3-way valve to use the solar system only when it can actually heath the water (up to a maximum temperature of pool water).
The 3-way valve I bought is controlled with a 230 V system, normally by a relay in a system like a Minisol or Digisol.
Can the Raspberry Pi be used to activate/switch the 3-way valve, using (probably) a PiFace?
I am not the electronics or electricity kind of guy, more the programming kind, that's why I am so unsure about it...
Thanks in advance for any information!
