Think the rumoured move to a VGA display option is pretty sensible. I've found the first day with an HDMI display a little frustrating:
None of my several current LCD monitors has an HDMI socket, I've discovered. Buying a new HDMI display seems to cost £110-120 as a minimum compared to £60ish for plain VGA. Yes I could have tried DVI-D on the couple of displays that have this but that would have meant sourcing yet another cable or adapter. VGA is - currently at least - the lingua franca among display inputs.
Fortunately, I have a 19" portable TV with an HDMI input. Should be plain sailing I thought. Not so: For a couple of hours got No Signal whatever I tried. Then after a final, final look at the manual I discovered that there was an obscure way of switching the input. Seems this particular Toshiba TV will try Ext1 automatically as an input, but Ext2, which it turns out is what the HDMI input maps to, requires some obscure button pushing to activate HDMI mode. The menu on the display only provides the default options of TV and Ext1. I still don't know exactly which buttons I pushed to get the HDMI mode - nothing seemed to work to start with and then all of sudden a supplementary menu appeared that offered me HDMI as one of the options.
Pleasantly surprised at the result of startx (remember I'm a 100% Windows user) and how easily I was able to browse the web. But switching to the graphical display did highlight that the display had defaulted to 1920x1080 which is too ambitious on a 19" TV. But I can't see any way of switching to a lower resolution within the graphical environment - what's the secret? All I'm offered is 1920x1080 or auto, which defaults to the former.
Is there a utility to set the clock - can't see that either - I know there's no RTC but there is presumably some simple way of setting the clock automatically at the start of each new session?
