Tue Jun 25, 2013 1:24 am
Okay, so I correctly installed the NOOBS software onto an 8GB SD card and it works fine. I hooked up my Pi with an off brand keyboard I had laying around and, no surprise, it didn't work. So, I bought the Logitech MK320 Keyboard and Mouse Combo and the Belkin Hi-Speed 4-Port USB 2.0 Hub model F5U234, and hooked up everything in the exact order specified by the instructions of both devices. I hooked up my combo to the hub and my Pi to a wall adapter and turned it on. (Keep in mind that I am using a power source for my hub) For some reason, no green light came on in the hub, and the mouse and keyboard were unresponsive. I unplugged everything and went through the entire process again, this time powering the Pi with the hub, and everything worked fine. I was able to select and install the Raspbian OS. However, after the Recovery Mode was finished installing the OS and restarted the Pi, bringing up Raspi-config, the green light in my hub turned off for the combo, and both devices became unresponsive again. I left it alone for 30 seconds to a minute in hopes of fixing itself somehow, but nothing. I again unplugged everything and started over, following the same steps, but this time, nothing happened at all. I repeated the process several times, and one time the Pi responded to my keystrokes about 30 seconds late each time. Other than that, my combo was left completely and totally unresponsive. Anyone have any ideas as to what is going on?
