p1ngu1n
raspbmc: Network drops/No connection
Sat Jun 22, 2013 10:32 pm
Hey guys,
since the last update I encounter regularly network problems. The network connection drops off and the three led's do not show any reaction at all.
What I checked so far:
- I got a new power supply with 5V/3A which should be enough.
- Checked the network cable and tried I don't know how many different
- Checked the switch and replaced it, no change
I tried running tail -f /var/log/messages during operation but when the network stopped working I did not see any event before that.
What else could I check? I'm kind of frustrated right now.
Thx
Jakob
pdsmith1981
Re: raspbmc: Network drops/No connection
Wed Jun 26, 2013 9:24 pm
I just received the update and can no longer connect to my network...Any ideas or help would be appreciated.
bayou
Fri Jun 28, 2013 10:08 pm
pdsmith1981 wrote:I just received the update and can no longer connect to my network...Any ideas or help would be appreciated.
Had the same issue. Changing the power supply solved the issue. Try also to disconnect any USB device. Hope this helps.
