Flav
Bash script and for loop counter
Thu Jun 20, 2013 7:30 am
Hi there !
Linux noob with Raspbian, I am writing my 1st bash scipt which there is a for loop.
In this loop there is an if condition, if the condition fails, I want to decrement the counter to start again with no impact on the final number of results (hope I am clear enough).
It seems I cannot modify the counter ("let" command doesn't work) and google was not a great help...
for i in `seq 1 10`		# exact number of increments TBD
do
	# Creates directory to store csv files, its name is date/hour based
	date=`date +%d-%m-%y_%H-%M-%S`
	mkdir $data/$date
	# Executes C program
	sudo ./main
	# Tests if csv files are present
	if [ -e $prog/*.csv ]
	then
		# Moves csv files from C program directory to data base directory
		sudo mv *.csv $data/$date
		# Delay before next C program execution
		sleep 1h		# exact delay TBD
	else
		# If no csv files present, add a message and restart after a small delay
		cp $data/.if_problem $data/$date/READ_ME.txt
		sleep 1
		let "i=i-1"
	fi
done
Does someone as a solution to work with the counter value ?
Thank you
Flav
Re: Bash script and for loop counter
Thu Jun 20, 2013 8:20 am
Yes, it won't work like that.
The "seq 1 10" command just returns a value of "1 2 3 4 5 6 7 8 9 10" and the "for" command reads each one of those in turn. seq is only executed once, so they can't change. "let" *does* work, but the for command will just read the next number from the sequence anyway.
Try something like
i=1
while [ $i -le 10 ]
do
   mkdir $data/$date
   sudo ./main
   then
      let "i = i + 1"
   else
      sleep 1
   fi
done
Note that it *only* increments the counter when a file is found.
Flav
Thu Jun 20, 2013 12:45 pm
rpdom wrote: Note that it *only* increments the counter when a file is found.
This is what I am looking for. I just need to add a kind of security to leave if the system doesn't work for a too long time.
Thank you for your help. ;)
