Tithis
Scanner permission issue
Wed Jun 19, 2013 5:37 pm
I'm trying to setup my pi as a home server and got samba and printing working perfectly fine. Today I was working on the scanner and am running into a bit of an issue I can't seem to find a solution for. Whenever I try to use the scanner for either xsane or command line I get this message
"Failed to open device 'pixma:04A91723': Access to resource has been denied."
The scanner works fine though if I run xsane as root, so there is obviously some permissions issue going on but I'm not sure where I would go to actually edit that.
It's a Pixma470.
Anyone have any ideas or past experience?
naicheben
Re: Scanner permission issue
Thu Jun 20, 2013 5:39 pm
Maybe add user pi to group scanner?
Tithis
Wed Jun 26, 2013 12:43 pm
I actually ended up getting it working a little bit before you posted. I was reinstalling it and thats when I noticed it adding sane and scanner. Got the little thing working perfectly as a file/print/scan server.
Thank you for responding though.
Return to “Raspberry Pi OS”
