mrbiz
HDMI Sleep
Wed Jun 19, 2013 9:37 am
Hi All.
I've had my Pi for a while now & am using it for all sorts of things. I'm a bit of a Linux noob though.
I use my Pi mostly for services (DNS, VPN endpoint, proxy, etc) so it is on all the time. But I given it it's own little HDMI monitor & keyboard next to my main PC for when I do want to do something on the Pi directly. The one thing that has been vexing me for a while now is that the Pi will sleep by making the screen go blank but it will not put the monitor to sleep/suspend. The backlight stays on so when I come into my office at night there's always this glow (read: wasted energy) from the monitor. Mostly it stays in terminal mode but it can be in X sometimes, but the sleep states are the same.
Is there a way to fix this? How to I play with the power management settings for the HDMI/display?
Cheers.
broo0ose
Re: HDMI Sleep
Sun Jun 23, 2013 8:48 pm
There's a set of instructions on this page that should help.
http://www.triggeredmessaging.com/blog/ ... d-graphite
mrbiz
Re: HDMI Sleep
Wed Aug 21, 2013 5:59 pm
Bump. I still have no control over HDMI power management. please help.
broo0ose
Re: HDMI Sleep
Thu Aug 22, 2013 2:14 pm
These are my notes on what I did for one project...
Make sure the Pi is set to the correct timezone using the raspi-config utility.
sudo raspi-config
eg. Europe/London
cron is the service that runs jobs at various times.
tvservice controls the HDMI
crontab -e
allows you to modify the cron table.
# m h  dom mon dow   command
# power saving
0  17  *   *   *     tvservice -o
0   8   *   *   1-5    /home/pi/screen_on.sh
this will run tvservice -o at 17:00 every day turning the screen off,
and run a screen_on.sh script at 08:00 every weekday morning.
contents of screen_on.sh
#!/bin/sh
tvservice --preferred > /dev/null
fbset -depth 8; fbset -depth 16; xrefresh
mrbiz
Re: HDMI Sleep
Tue Aug 27, 2013 6:45 pm
cheers, i'll give it a shot, but still it's not really power management. I mean, the RPi does screen blanking there must be a way to change the method used, it is Linux after all???
broo0ose
Re: HDMI Sleep
Wed Aug 28, 2013 3:54 pm
'tvservice -o' puts the monitor into sleep mode, the LED on the screen goes from green to orange, there's no glow.
gkreidl
Re: HDMI Sleep
Wed Aug 28, 2013 4:19 pm
Nobody seem to understand the real problem: There should be a way to set the monitor in sleep mode automatically, instead of just blanking the screen. All my other Computers do this (Linux and Windows).
It's simpy a question of saving power.
Minimal Kiosk Browser (kweb)
spongman
Re: HDMI Sleep
Fri Sep 06, 2013 12:33 am
bump.
is there really no way to do this?
just think of the trees!
AGWA
Re: HDMI Sleep
Wed Jan 08, 2014 5:54 am
The kernel driver for the Raspberry Pi's GPU does not support the function that X uses to put the monitor to sleep. I have opened an issue about this here:
https://github.com/raspberrypi/linux/issues/487
Until this issue is resolved, it won't be possible for X to put the monitor to sleep on a Raspberry Pi.
__Plasma__
Re: HDMI Sleep
Sat Apr 02, 2016 10:59 pm
This I still a problem for me, I know this thread is old but surely this should have been fixed by now?
I'm running an rPi 3 with the latest Jessie release, screen goes blank, but the screen is still awake. I too would like to save energy, with a Windows PC the screen sleeps properly.
Plasma
AGWA
Re: HDMI Sleep
Sun Apr 03, 2016 3:07 am
Plasma: addding
hdmi_blanking=1
to /boot/config.txt should fix the issue.
__Plasma__
Re: HDMI Sleep
Mon Apr 04, 2016 8:57 pm
Fantastic that has indeed solved my problem.
Plasma
gkreidl
Re: HDMI Sleep
Mon Apr 04, 2016 9:12 pm
AGWA wrote:Plasma: addding
hdmi_blanking=1
Unfortunately this keeps some applications (gstreamer1.0 based) from working and may even crash the system.
__Plasma__
Re: HDMI Sleep
Mon Apr 04, 2016 9:32 pm
hdmi_blanking=1
Any suggestions on a better way to enable this functionality? Its likely I will only be using Raspian with the Web Browser and Kodi.
I am running it as a Media Centre in my kitchen, so a few recipes and some movies are all I need.
Plasma
HankB
Re: HDMI Sleep
Tue Apr 05, 2016 2:56 pm
Thanks, works for me too.
shiekh
Re: HDMI Sleep
Sun May 14, 2017 4:10 am
Absolutely brilliant; I've been looking for this for some time now. At $1 a Watt (for a year) it was a big deal for me.
skypi
Re: HDMI Sleep
Fri Jan 26, 2018 10:06 pm
yeah that works! cool!
where is the delay time setting?
and, yeah, that measurement of 1w 24/7/365 at $1 per year is very interesting measure!
skypi
Re: HDMI Sleep
Fri Jan 26, 2018 10:59 pm
so the $1 per watt per year is still cheap wherever they are eh!
about 17p /unit here! (inc. standing charge)
so... (1w * 24 * 365)/1000 = 8.76
8.76 * 0.17 = £1.49
= $2.11 per watt per year
timattrn
Re: HDMI Sleep
Mon Jul 23, 2018 2:51 am
hdmi_blanking=1 in config.txt did the trick for me, but it was hard to discover about this (for me, a newbie).
It is documented here
https://www.raspberrypi.org/documentati ... /README.md (in the Video section)
which also includes a warning
"NOTE: This feature may cause issues when using applications which don't use the framebuffer, such as omxplayer."
The power saving for me is not just the raspberry pi, but the monitor itself, not to mention that the backlight has a long but finite lifetime.
The saving may be more like 10W, I reckon it's about AUD $17 year, which is about the cost of the Raspberry Pi Zero W.
