truk
what is the command to start X?
Tue Jun 18, 2013 6:36 pm
I have the desktop set to not launch on boot, but if I want to pop into the desktop what is the command?
mahjongg
Re: what is the command to start X?
Tue Jun 18, 2013 6:58 pm
the command to start x is
startx
what else would it be? :D
redhawk
Tue Jun 18, 2013 7:34 pm
init 5?? :D
Richard S.
mahjongg
Wed Jun 19, 2013 12:49 am
you mean run level 5? thats is not a command afaik.
or am i talking rubbish? :oops:
Wed Jun 19, 2013 3:32 am
mahjongg wrote:you mean run level 5? thats is not a command afaik.
On some *ix systems, run level 5 is "multiuser + X + network" mode, while run level 2 is "multiuser + network" only. Run levels 3 and 4 also have specific cases. Debian based systems (like Raspbian) don't differentiate between levels 2 to 5, network is up in all, multiuser is available and X will start if it is installed and configured to start.
truk
Wed Jun 19, 2013 3:36 pm
mahjongg wrote:the command to start x is
startx
Thanks! I'm very new to linux and after trying
run x
start x
execute x
x
sudo x
go go gadget x
how the heck to I start the stupid UI?
I figured asking would be good.
Is there a command to stop X? I've already tried stopx.
JeremyF
Thu Jun 20, 2013 1:34 am
startx
run x
start x
execute x
x
sudo x
go go gadget x
Ctrl-Alt-F1, then Ctrl-C -- only works if you're using the Pi in person
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
Thu Jun 20, 2013 5:05 am
truk wrote: Thanks! I'm very new to linux and after trying
x
Very close there. I've not checked on the Pi (I don't use X on mine), but just X on it's own should work too (one of the few upper-case commands on Linux).
Using the "logout" option from the application menu should shut down the X session (again, working from memory, as I don't have X). Also, Ctrl-Alt-BackSpace may work, but that is disabled on some Linux installs.
startrek.steve
Thu Jun 20, 2013 8:34 am
Easier than that
killall Xorg
May not be a clean exit, but I do it all the time on the Pi.
Pi 2 running LibreElec Krypton, Pi 2 running Wheezy Desktop, Pi 1 headless Wheezy, downloading Radio, Pi 1 running Picore headless Media Server, Pi Zero to be an Old Time Radio Project. Pi 3 testing. Pi Zero W downloading Radio shows headless.
Joe Schmoe
Thu Jun 20, 2013 8:37 am
Ctrl/Alt/BackSpace
startrek.steve
Thu Jun 20, 2013 10:29 am
Hmm thought that was only Gnome..
redhawk
Thu Jun 20, 2013 10:37 am
kill -1 -1 is quite brutal (terminates all login sessions and running programs) but nevertheless it should close down X. :)
Richard S.
samson241
Thu Jun 20, 2013 6:20 pm
redhawk wrote:kill -1 -1 is quite brutal (terminates all login sessions and running programs) but nevertheless it should close down X. :)
Richard S.
love that...
I realize this question must seem stupid and i apologize in advance.
